#112545 - December 06th 2006 7:36 pm
Re: Rear End: Gear Ratios, brands, noise levels
[Re: ]
Loc: West Chester PennsylVANia USA
If your using a OD trans 700R4 or a 4L60 your rpm with 373's at 70 MPH will be about 2300 thats not to bad I say about because tire diameter comes into play.
There are a lot of RPM calculators online I had one but didn't keep it in the favorites. I think the final gear ratio of the OD box is .076
Take Care, Billy
Have Van Will Travel
#112567 - December 06th 2006 9:44 pm
[Re: Billvill]
Loc: Morris Cty, NJ
As far as my wheels go they should be stock rolling diameter or close to it. I'm a big fan of running that way, I know anything can be adjusted but still. I'll be running 17's when i get my summer wheels but overall they'll be the same diameter as the 15's I run now with their stock tires. I havent a clue what kind of tranny i'm running though I believe it doesnt have an OD. We already have the backlash tool and according to my friend anything else we'd need. Seemingly I'm at the point that I can go ahead an order other than not knowing the spline size whether 28 or 30. I wanted to know that before I ordered to keep the rig on the road as long as possible with as little down time as possible but that might be unavoidable.
#114122 - December 16th 2006 10:06 pm
[Re: FroOch]
I wrote a post about a month ago http://www.vannin.com/threads/ubbthreads.php?ubb=showflat&Number=80410&page=1#Post80410( See 407 stroker ) about chevy 10 bolt rears. Most drive line parts break on the launch. If your not going to put 12" slicks on the van and try to pull the front end off the ground it might hold up. Consider the fact that the its a van and 65% of the weight is in the front. Most of the time you will be spinning the tires. You won't be hitting the NOS until second gear. Before you spend the big bucks for a Detroit locker and a Ford 9 " carrier you will have to have shortened, have a look at this site. It has some good info on the 10 bolt. http://www.chevyhiperformance.com/techarticles/48518_posi_10_bolt_upgrade_install/index.html After I posted this, we have had some real nice weather here in the east so I took advantage of the sunshine and got a few things done to my heavy full size Beauville window van. Swapped out the TBI unit with a bored and polished throttle body. Fuel pressure adjustment via an adjustable regulator I added to the TBI unit. A fresh set of plugs. A fresh fuel pump. It was due to be changed out anyway had 115k on it. ( thanks for the help Josh ) Bumped the timing a few degrees. and so on. With the 8.5 10 bolt rear and the OEM governor style posi, it lock up and spin the tires when I nail it from a stop. I have some decent sized BFG's on there too. I don't expect to be doing that everyday and I certainly don't expect it to hold up if I was. I said before in a post. The factory Chevy governor posi is good set up not to be overlooked for a daily driver. ps: In case you havent seen one of these rears, the difference between a convential posi and a governor style carrier is that the governor via a centrifical arm moves out when you have a free wheeling side gear ( one wheel spinning when your in mud or snow ) and then engauges the posi clutches. All other times it operates as a regular open end rear. no noise on turns no posi clutch wear during daily driving. This is just my opinion. I hope you like the idea.
Take Care, Billy
#139032 - June 09th 2007 3:48 pm
[Re: Billvill]
If you haven't swapped out your rear end gears yet, I can highly recommend the 3.73's with the overdrive trans. I ran up to LMDW a few weeks back and it was my first highway trip with the 3.73 gears in the truck. It ran great at 75 in OD with a light trailer. The van was begging to be let out but I have never seen so many cops on the Thruway. Here is the real kicker, the fuel mileage was the best I have ever had from any of my TBI motors.
Take Care, Billy
#139197 - June 11th 2007 9:31 am
[Re: Billvill]
I have 2:73's in my 1978 Chev with a 3 speed Auto...runs at 70 no prob, and about 14 mpg In the Astro, when I blew the differential up, I went from 3:55's down to 3:23's ....lots better mileage. In the Dodge, I have 3:90's 0-60 in 6 blocks, but runs all day at 70.00 with about 14.5 MPG The Aerostar with a Flat Head, 8 inch posi with 2:90's so far
#139200 - June 11th 2007 9:45 am
[Re: Doc 2% of Canada, EH!!!!]
In my lawn tractor, I have 8.20's an it get terrible mileage in 3rd gear with the blades engaged. Eh
Take Care, Billy
61
6611 Members
25974 Topics
