#127977 - March 23rd 2007 12:58 am
Adding 2nd alternator in place of A/ C compressor
Loc: sacramento
hi, Ive got a lot of exterior lights on my van, and am considering the idea of adding a second alternator. I removed the A/C compressor years ago, leaving a flat surface thats looks perfect for modification for support of a second alternator. But before going that far, does anyone know of a bracket that i can swap with. This piece, where the A/C used to be, also provides the two tabs that the primary alternator connects to, so if there is a alternate piece, it would have to support the mounting of 2 alternators.
Ive got a 78 dodge van , with a 360.
Viva La Vannin!
Proud driver of a 1975 Dodge B200 Maxi/318, Panel. Rust In Peace: 1978 Dodge Maxi/360 panel.
#127982 - March 23rd 2007 6:46 am
Re: Adding 2nd alternator in place of A/ C compressor
[Re: Scrotor]
Not sure if there is a specific bracket that would bolt right in. You may have to have a bracket made. I like the idea of two alternators. I guess you'll need voltage regulators as well.
I like your avatar. "Whatcha gonna do brother, when the 24" pythons and Hulkamania run wild on youuuuuuuu!"
#128217 - March 24th 2007 10:30 pm
[Re: Vanishing Breed]
Loc: sacramento
Thanks nate, I recommend, if you have a source for MP3's downloading, to do a search for "Hulk hogan and the wrestling boot band" Nothing like cruising in the van with "i wanna be a hulkamaniac" blasting.
I may take Vanishing breeds suggestion on a higher rated alternator. Then all that would be needed is the regulator upgrade and an lower guage cable.
Is there any suggested place to pick up a 200 amp alternator? And whats the cons on the alternators with the built in regulator.
Thanks again!
#128234 - March 25th 2007 12:00 am
[Re: Scrotor]
My '94 uses a 120A Nippondenso alternator and it's a fully loaded conversion van. I'm pretty sure you can use your existing brackets to mount this alt., but you have to swap pulleys and make your own wiring harness. Some in the Mopar muscle-car world have done this swap. http://www.moparts.com/Tech/Archive/elec/22.html
#128251 - March 25th 2007 8:29 am
Loc: West Chester PennsylVANia USA
You might have good luck at the salvage yards looking for an older Dodge ambulance. The ones I wrenched on back in the day had Neville Bliss (sp) alternators that are huge. They all had 360's in them and I think they put out close to 300 amp. You could score the brackets and the wiring and any special belt setup. It is my understanding they are still used today in ambulances and fire trucks and easy to rebuild should the need arise.
Take Care, Billy
Have Van Will Travel
#128405 - March 25th 2007 11:50 pm
[Re: Billvill]
Loc: San Antonio, Tx.
I'd also recommend a higher output rather than a 2nd one. The drag on the engine would not help fuel mileage at all. They make alternators to power portable welding equipment, cheaper than the higher output ones you get at stereo shops. Power Line is one. Don't forget to get the voltage regulater for it. Had a 225 amp in my 85 Dodge. Some of the newer conversions are running 135 amp alternators, so that may even work.
2005 E350 Turbo Diesel, 1993 G20 350 Chevy Why is it that when I press 1 for English, I still can not understand the person on the other end????
#128779 - March 28th 2007 12:47 am
[Re: Starlord]
Loc: sacramento
Juicy!
Thanks for the suggestions!
#128987 - March 28th 2007 11:36 pm
[Re: Scrotor]
Loc: Rocky Mount NC
Cop cars, motor homes used a honking huge 100 amp alternator. Were I you I would look for an 88 Dodge van (parts van). Grab the late alternator and tensioner and brackets. It uses V belts and should swap right in with no problem. YOU MAY HAVE TO CHANGE ALL the pulleys, be fore warned (I ran into this in swapping a 87 to 77 parts- you have to get the whole shebang1) I believe its a internally regulated unit... however Im not sure. I dont think there is a problem double regulating an alternator, either- simply wiring your field wires onto the late altenator... i did this and it still charged on a 93 mini van alternator.
<img src=http://i24.photobucket.com/albums/c11/Vantravlrs/pt2.jpg alt= - /]
74
25970 Topics
