by redrooster
37 minutes 3 seconds ago
Beefing up front suspension
Today at 04:52 AM
color coded dash bulb holders
by Matman
Today at 03:26 AM
my BRUBAKER BOX
by 77Quadravan
Today at 02:02 AM
by 77Quadravan
Today at 02:00 AM
by 77Quadravan
Today at 01:58 AM
by nightdragon
Today at 12:46 AM
vent visor or rain gaurd
Today at 12:17 AM
Wookee
Today at 12:11 AM
by zank
Today at 12:10 AM
#157005 - October 18th 2007 7:37 pm Sealer in large gap?
Hi, I'd like to ask some advice of those of you who've been in the van bodywork business for a while.
I was working on the interior floor of my '81 dodge maxi van last night hitting some areas with phosphoric acid prior to painting, and I noticed some of the seam sealer at the joint between the channeled floor pan and the flat wall pans was bit loose. Suspicious of this, I pried it up and found a thin coating of tight orange surface rust under it, so I scraped it all out on both sides of the van and etched those areas as well.
I scraped the whole way back to the base of the rear door support posts, and to my amazement, after scraping out all of the sealer there, there was an enormous gap at the base of each post - nearly 3/8"x3", which had been filled with the factory sealer. (The factory sealer looks like a white butyl rubber caulk, (at best) and at worst, it might even be plain bathtub caulking - it sure feels like it!)
On Nate's advice I recently bought some high quality brush-on seam sealer from Eastwood, but I don't believe it's thick enough to fill such large gaps... should I use some butyl rubber to fill the largest portion of the gaps? What sort of treatment do you think I should apply to the underside of the gaps (which would be outdoors) -which appear to be bare of *any* treatment to me.
Thanks for your assistance!
#157010 - October 18th 2007 7:50 pm Re: Sealer in large gap? [Re: Ram4ever]
leadfoot Offline
Loc: Connecticut
without a pic it's hard to see what you got goin on there
but from what i'm hearing you may want to cut some strips
of sheetmetal to cover the "gap" (like a long band-aid)
quality seam sealer of some tuff stuff
brush on some to the gap, lay the sheetmetal strip over the opening
and brush a couple coats over the top
(don't try to pile up seam sealer too high it won't cure completely)do it in coats, it don't hurt to even let it set over night between them
there is alot of car building going on with "no weld panels"
and it's all put together with seam sealer/glue
i did a door panel the other day...
well ok i did a window regulator the other day
but had to remove the outter door panel to get at it!
the whole thing was glued together
most important is remove any old rust before doing anything
and it'll last a long time
#157013 - October 18th 2007 7:55 pm Re: Sealer in large gap? [Re: leadfoot]
Sorry, I figured this might have been a well known issue... I'll go take some pictures so you can see just what Dodge did. I'm amazed they wouldn't have done a better job of fitting the sheet metal.
-I'll be back shortly!
#157016 - October 18th 2007 7:59 pm Re: Sealer in large gap? [Re: leadfoot]
weird Harold Offline
Loc: Powers oregon
I had a 76 ford that had a problem like yours i did a chop glass filler and a glaze over it never did rust there the rest well lol.
Member of Lead Foot Trucker West Coast Chapter Pea On
#157021 - October 18th 2007 8:17 pm Re: Sealer in large gap? [Re: weird Harold]
Old flattened beer cans, crazy glue, silicone then seam sealer was the way used car dealers did it....With the price of scrap metal, it is probably done now with wads of paper, duct tape and Bondo...lol
Seriously, send pics, it sounds to me like something else is going on, like maybe collision damage ??????
97Errorstar,05 Freestar
Ottawa Valley Vans
Founder,Mixed Bag Truckers
#157023 - October 18th 2007 8:21 pm Re: Sealer in large gap? [Re: Ram4ever]
Ok, here's a picture of each side. It's a pretty substantial gap. The dark areas are literally the outdoors. You can also see a sloppy welder's MIG wire left behind... I've found several of these so far.
What do you think?
#157025 - October 18th 2007 8:24 pm Re: Sealer in large gap? [Re: Ram4ever]
BvrWally Offline
Wood Carver, Supreme
Loc: Earlyville,Ohio,USA
Like Harold mentioned earlier, glass it and work from there!
B.W. smile
#157026 - October 18th 2007 8:25 pm Re: Sealer in large gap? [Re: Ram4ever]
BTW - The chunks of material in the 2nd picture are some of the seam sealer I mentioned. Sorry I didn't clean it up much before taking the pictures; the acid is still a bit wet which makes it looks pretty ugly.
#157033 - October 18th 2007 8:43 pm Re: Sealer in large gap? [Re: Ram4ever]
leadfoot Offline
Loc: Connecticut
dammm man thats ugly
some good bondo hair/fiberglass will be more cost effective
add some metal where ya can
seam sealer aint cheap stuff, and not for stuff that large IMO
but being a floor area and most likely covered it doesn't need
to be "finished" looking, just solid and water tight
that bottom pic looks like one violent cut
can you post a pic of the area it's in ?
(like the whole floor pic to have an idea where this is at
and how much of it)
#157058 - October 18th 2007 10:44 pm Re: Sealer in large gap? [Re: leadfoot]
Preacher Offline
Keeper of the Book of the Great Legend
Loc: North Carolina
Hey Ram:
Get some decent seam sealer. NOT PURE SILICONE, one of the latex ones is better for this. then, get some aluminum flashing at home depot or someplace. Cut a piece to fit, whatever shape you need it to be, put it in place, drill some 1/8th diameter holes wherever you think it will help hold the patch in, put some seam sealer around the edge of the hole, (and DO NOT BE STINGY WITH IT) then, put your patch in place, and pop rivet it in place. (sheet metal screws will work too, but they stick up further.) If you really wanna make it permanent, and a little prettier, after all this drives, cut the sealer flush, rough up the aluminum with some 40 grit, along with the metal around the patch, and lay some bondo-glass (one brand is "Gorilla hair") on it smoothing it out best as you can. You wont ever have to worry about THAT hole again..lol
hope this helps,
God bless,
Preacher
p.s.: if you got bolt holes you need to fill, old biker trick from the 60's: you need an old fashioned soldering iron. (the big kind) some 000 steel wool, and some plumbing solder. (acid core) . Clean around the hole. Make a ball of steel wool that will fit in it and "blossom" just a little on both sides. Heat the wool with the soldering iron, and soon as it will melt solder, lay into it with the solder...fill it UP....let it dry, file it down, bingo, no hole no more..
(we used to do this to fill bolt holes in fenders before the days of custom bike parts all over the place)
0 registered (), 3 Guests and 59 Spiders online.
6694 Registered Users
Wizard78 365
frscke1 337
Uncle_Fester 243
NateNCBV 212
Lee7673 177
26236 Topics
