#210580 - June 16th 2008 10:58 am
New (?) V-8 question for ya........
Okay all you out there with V8 Astros, here is a question I have not seen covered.....What kind of MPG does a V-8 (5.7 TBI) Astro get?
Bueler? Bueler? Anyone?
Just FYI, this is a 1990 AWD Astro, with 255/60/15 tires (well, thats what they will be soon) If I do this swap, it will be with a remaned 5.7, stock roller cam, shorty tube headers, a swirl type TBI spacer (trans-dapt?), stock TBI intake / maybe Edelbrock Performer TBI intake, stock HEI distributor, and K&N air filter.....very mild build up, guessing 300 HP?
One other question on V-8 swap.....can I use my stock computer and but a new custom burned chip, or do I have to change computers out, and if so...does that require a rewire? Thanks for all the help everyone.
Oh, reason for this swap is I spun a rod bearing, and can only afford to do a bearing replacement right now...going to drop the oil pan, lightly clean the journals with emery cloth, and replace the bearings.....band aid fix at best, should be good for about 6 to 10K miles, time to build the new motor.....so do I do a 5.7 or a 4.3? I HAVE to keep some sort of MPG as this is my daily driver.
#211253 - June 19th 2008 4:36 am
Re: New (?) V-8 question for ya........
[Re: Superbeast]
Well, it is a mute point now...as the Astro is dead and gone, If you read my post in the General section, you will understand..... http://www.vannin.com/threads/ubbthreads.php?ubb=showflat&Number=211250&page=1
90
25908 Topics
