non-traditional, not old-school, Graphics for a moto/camper van
by mwilliamshs
2 seconds ago
J&J fiberglass being made from J&J molds
by mwilliamshs
19 minutes 30 seconds ago
Meet big Bertha!
by ignitionlive
42 minutes 17 seconds ago
My 4x4 is Featured on the LMC truck life website this month
by VanPLan
Today at 05:08 PM
Super Somer 13 "A Custom Van Event"
by Pat ALTRUK
Today at 04:45 PM
Sport Wheel Center Cap Bolts
Today at 04:15 PM
Van quote
Today at 03:51 PM
Remember these JY panels
by VanPLan
Today at 02:33 PM
Fuel Guage Sending Unit - 76 Dodge
by bootsy100
Today at 01:52 PM
list of seat bolt patterns
by mwilliamshs
Today at 01:25 PM
#293005 - May 18th 2009 1:46 pm engine swap
flyercaptainstump Offline
Loc: Winamac, Indiana
does anyone have any info on performing an engine swap on a newer gm g van from a tbi v-6 to a tbi or carb v8?
91 Chevy G20
06 Chevy 3500 (paper delivery)
08 Dodge Caravan (children delivery)
81 G-Van Wee Vans (good times delivery)
Don't run out of altitude, airspeed, or options at the same time.
#293007 - May 18th 2009 1:50 pm Re: engine swap [Re: flyercaptainstump]
vanatic05 Offline
Vanaholic
Loc: Auburn IL
You will need to grab as much as you can from donor van especially wiring harness and computer, usually the computer is under drivers seat or inside wall panel behind drivers seat..other than that it should be fairly easy swap..
Darrin Bentley
Director: Vanatics Van Club
92 GMC 3500 454/4bbl
roiboi65@yahoo.com
www.vanatics.com
#293011 - May 18th 2009 2:02 pm Re: engine swap [Re: vanatic05]
any clue as to what years older and or newer would work? what year did they start with tbi f.i? 88? so would up to a 95 work?
91 Chevy G20
#293012 - May 18th 2009 2:03 pm Re: engine swap [Re: flyercaptainstump]
I ain't got no time for no jibber jabber from a wimpy v6 engine. smile
91 Chevy G20
#293016 - May 18th 2009 2:12 pm Re: engine swap [Re: flyercaptainstump]
just talked to my buddy at the chevy store. he says....88-95 pretty much the same except sensors may be moved year to year. 4.3 is a 350/305 with 2 cylinders whacked off. tbi is the same, might have to swap out the injectors, for more flow. alternator, ac, power steering, accessories, engine mounts are all the same as a 350. he says biggest deal to get it to fit is swapping out the fan shroud, which isn't a big deal. he also recommended a 91 or newer engine for performance issues related to the early tbi's. if anyone has done this lemme know if there is already a thread here about how you went about it. thanks
91 Chevy G20
#293028 - May 18th 2009 3:15 pm Re: engine swap [Re: flyercaptainstump]
G_ROLLER Offline
Loc: St. Louis Metro
I wanted to swap out a 4.3 from an Astro with a 350 so here's what I found out. (By the way I have one that was done but I did not do the doing). As it was said earlier in this thread a 4.3 is nothing more than the Chevy V-8 small block missing two cylinders. Your V-8 should bolt right up to the transmission and motor mounts (with the Astro there was a special motor mount available). I was told by my local shop that specializes in converting carburetor engines to tuned Port injection with all the electronics that I should use a 1989-1991 vintage 350, he said those are most compatible. You do have to change the computer (on the 91 Astro it was behind the kick panel on the passenger side I believe, you can either change this out with a junkyard or what I think is best to have it read program. all in all everything should go together fairly simple, you will have to do something with the fan shroud. If this is an Astro swap what seems to work best is removing a fan and going with an electric water pump and electric fan, thataway you don't worry about the mechanical fan being too close. The shop that gave me most of my information is "Larry's Electric, Ruma Illinois". This guy is great when it comes to anything automotive electrical, he's the one that fed me all my information and also reprogrammed my computer (the guy that put mine together forgot to mark the computer so I had to have the reprogrammed just to make sure).
Vantopia II
06-06-2014
1 registered (ignitionlive), 3 Guests and 27 Spiders online.
dmati, lmnopq750316, Izzydoesit, defghi231746, Ebonypleasure
7712 Registered Users
HighwayStar 153
newkirkinc1 125
lukester 111
al55 101
Reed 97
Glitch 79
apo234 78
jules73 75
cjhardcore 71
frscke1 70
7712 Members
29556 Topics
