by zank
pin up girls
by loosweel
Latest tuner trend. . . .
by Bryce
05:53 PM
Van failed emissions twice
by Shagbox
05:50 PM
05:45 PM
05:22 PM
05:21 PM
Page 3 of 4 < 1 2 3 4 >
#314440 - August 02nd 2009 12:44 pm Re: Converting to Power windows on Phoenix [Re: Phoenix]
Yesterday I got the hole saw out and cut into the doors and got everything mounted. Ran the wiring harness through the rubber plugs in the door and door sill in the rubber flex conduit.
This morning I got all the wires bundled up and tied securely.
I did find the Power window terminal on the Ron Francis fuse box which was convenient, I found the instrument light wire and scotch locked the window switch light wire into that.
All that was left really was vacuuming out the doors getting any stray metal shavings out that might start the "demon RUST". Then putting on the door access panels. For you guys that have Dodge Vans, Ill bet everyone has at least one or three if not all screws that hold the access panels on your doors are stripped or close. Here is a little trick that will give your screws a bit more bite. A Vice clamp clamped tightly across the screw hole in a couple directions presses most of the metal back into the thread area in the screw hole and if you do not get real rough with a screwdriver your screws will hold the panel securely again without any rattles
#314563 - August 02nd 2009 7:18 pm Re: Converting to Power windows on Phoenix [Re: Phoenix]
That's really looking nice Phoenix!
And thanks for the great pictorial - I'm always happy to see those areas of vans that I don't get into very much; I learn things from them, and it keeps the pictures in my mind from drifting too far off course!
#315574 - August 04th 2009 9:24 pm Re: Converting to Power windows on Phoenix [Re: Ram4ever]
No broblem THX for letting me know I still have alot to do on Phoenix. I'm not afraid to show what is going on with it. Glad to add some input
#323118 - August 31st 2009 12:34 am Re: Converting to Power windows on Phoenix [Re: Phoenix]
86ed Offline
Loc: puyallup,wa
well i got the power windows out of my '86 Dodge and into my '75. i have the same kit as Phoenix used, i think i paid $320 two years ago. i seem to struggle on about everything i touch and this took me the whole weekend to finish and a lot of aggravation. ended up having to put the windows from the '86 into the '75 because of the bigger slider. measured the mounting holes from the '86 and transferred them to the '75 and drilled them out. its tough to find a good spot to get the wiring from the door to under the dash. i ended up putting the '75 crankers into the '86. had to measure that out also, should of probably got some from the same year out of the wrecking yard, would have been easier but i went cheap. i see why they changed the window crank location in '78 with the new dash because your gonna be bustin your knuckles with the '70s style in an '80s style, its about a 1/2 from the dash. anyhow it's done and they work great, love power windows.
Edited by 86ed (August 31st 2009 12:37 am)
#323351 - August 31st 2009 8:45 pm Re: Converting to Power windows on Phoenix [Re: 86ed]
I justused the big gromet in the door and body and a conduit between and no problems . Had a clean looking install and an very happy with mine....grin
#323381 - September 01st 2009 12:02 am Re: Converting to Power windows on Phoenix [Re: Phoenix]
86ed Offline
Loc: puyallup,wa
where that grommet is on the body of the '80s Dodge, the '70s Dodge your in the vent area. then you need to drill another hole to get under the dash area. just worried air or maybe even some water could drip down inside. i'll just have to put some sealer on that spot.
#327036 - September 17th 2009 7:58 pm Re: Converting to Power windows on Phoenix [Re: 86ed]
I really think the sheet maybe has not changed from the 70's inside I went through the vent hole above the plastic inner trim
#559583 - May 01st 2012 11:25 am Re: Converting to Power windows on Phoenix [Re: Phoenix]
Vanther Offline
Loc: Spokane, WA USA
Phoenix do you have any pics of installing the hot rod contact strip, or did you go straight with wiring and a loom? That van looks great!
#559702 - May 01st 2012 9:56 pm Re: Converting to Power windows on Phoenix [Re: Phoenix]
That whole thread is pictured in detail, you just have to look it up and see what I did . I am sure I just used the wire loom conduit tube and ran it through the cap plugs in the door and body. I am sure there are pix showing it. I can take some more if you want me to. Just let me know , Happy to help.
#559915 - May 02nd 2012 7:49 pm Re: Converting to Power windows on Phoenix [Re: Phoenix]
I do have some of those multi contact hot rod door contact strips but never used them. The wire loom stuff just was too easy and time was short. Joe (J&J Fiberglass) gave me two sets of multi contact door contacts to use but I never did . Probably should have but, like I said,... time...! Check the thread out It does have a step by step install on those window lifts
3 registered (redvan8, Reed, spaceman&maria), 8 Guests and 67 Spiders online.
diamond dan
Wizard78 304
Uncle_Fester 296
NateNCBV 227
keystonekid1978 126
al55 113
Reed 107
newkirkinc1 105
6607 Registered Users
6607 Members
25959 Topics
