New to site- 89 vandura
by Captain_E
8 minutes 19 seconds ago
New member from Knoxville, TN
by Captain_E
16 minutes 57 seconds ago
newbie from Tennessee
by Captain_E
22 minutes 57 seconds ago
by Captain_E
26 minutes 18 seconds ago
My dodge van project.
by DodgeVanCorvette
Today at 02:58 AM
Can I swap dash from 79 to 94 Chev G20 ?
Today at 01:42 AM
whats in a name
by OldReadingGus62
Today at 01:42 AM
My '72 Corvette Dodge Van
by DodgeVanCorvette
Today at 12:40 AM
Van Jam 38 SUPER HERO Truck-in Friendship, IN April 25-27 2014
by Suzie-BGfNY-IN
Today at 12:20 AM
Need help in selecting a van club
by Suzie-BGfNY-IN
Today at 12:16 AM
#348104 - December 11th 2009 7:23 pm '78 Dodge 318 2-bbl to Holley 4-bbl swap
keystonekid1978 Offline
Loc: Lancaster, PA, USA
I picked up a Weiand Action+Plus aluminum intake and a 600 cfm Holly 4160 carb recently, and I'm just starting to get everything bolted together. So far so good, but I'm having some issues with the throttle lever and trans kickdown. The factory linkage doesn't work right with the Holley carb, nothing lines up. Has anyone out there done this swap? I know Holley makes a mopar throttle lever adapter, but I'm not sure if that will solve the problem or not. Another option would be a Lokar adjustable throttle cable and kickdown kit, anyone had any luck with these in the past?
Matt K.
Flyin' Dutchmen Vans, Lancaster PA
1983 Dodge B150 Shorty
amazon add parts
#348138 - December 11th 2009 11:14 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: keystonekid1978]
SixShot Offline
Loc: Joyce Washington
Been awhile since I've done a similar swap,get the Holley linkage adapter trust me it'll work.The kick down wasn't a problem on mine just needed adjusting to get it set right.The kick down is critical so take your time adjusting it to factory spec.Good luck
#348176 - December 12th 2009 12:23 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: SixShot]
Probably hard to find, but getting linkage from a factory 4bbl. equipped van might work too.
Lloyd's idea is probably better. smile
#348181 - December 12th 2009 12:54 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: NateNCBV]
SixShot Offline
Another thing that might work...On my 83 slant6 with Eddy 4brl I 'home engineered' a cable throttle setup.Pulled the stock pedal and cable from a 90 Dodge TBI,drilled 2 holes to mount the pedal(it mounts to the front not side like ours) another for the cable.This gives you a nice long cable to go around the carb and pull from the back and gets rid of all the rods/bell cranks and alignment problems that you have now.That would also be a bunch cheaper then Lokar plus stock Dodge cable not special order if you needed to replace it.If you do something like that just make sure when you drill new holes that the starter relay or wiring won't get drilled and no I measured thrise and drilled once no booboo's lol
#348595 - December 14th 2009 2:39 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: SixShot]
SixShot, which adapter did you use? Holley offers 2, this one, which is only 8 bucks, and this one, which is almost 30.
Matt K.
#348603 - December 14th 2009 3:46 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: keystonekid1978]
SixShot Offline
I'm thinking it was the 8 buck piece.Keep in mind that when I did my 318 4brl your van wasn't even built yet shocked Try that piece first and see how everything lines up then go from there.You should be able to pickup those adapter pieces from a local parts store,might cost a bit more then Summit but no waiting.
#348891 - December 15th 2009 3:47 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: keystonekid1978]
86ed Offline
Loc: puyallup,wa
i have an Edelbrock carb and manifold so this might be different. that $8 looks like the one i used. the rod closest to the carb is the cruise control. i got a piece of aluminum from Lowes and bent it to use from carb linkage to the setup behind carb. it is about 1 inch longer then the stock one. on the kickdown linkage to the trans i screwed it out as far as i could and added a bolt and nut to get it out farther so it would shift correctly. the piece that everything hooks to is the stock piece but i dremmeled it down and made new notches and drilled a small hole through for the pin to go through. had to make it shorter so it didn't hit the black rod from gas pedal to rear linkage. workin pretty good but i really have to mash the pedal too get it to kick down, still need to adjust a little. i still need to do a little fine tuning but i'm happy with it . i haven't seen what others are doing but there has to be many 4 barrels on out there. hope this helps somewhat
Edited by 86ed (December 15th 2009 3:49 pm)
#349021 - December 16th 2009 7:39 am Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: 86ed]
woodchuck Offline
Loc: gettysburg, pa. usa
Hey Kid,, Woodchuck here,, I just took my Holley off of the 73 and installed a Elder. Basiclly looks like the same linkage as 86's pic. showed and didn't have to change a thing.. Being that you are going from a 2 to 4 barrel will present a little more different but Holley kit should help you out.. If you need help with anything give me a call.. Glad to see that you are still vannin and hope to see you again..
#349113 - December 16th 2009 2:51 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: woodchuck]
I went ahead and ordered both pieces from Summit, I'll just return which ever one doesn't work. I also ordered a trick little throttle return spring assembly, manual choke cable, some chrome valve covers and a chrome 14" air cleaner, and some other dress-up goodies. I've been taking plenty of pics, which I'll upload as soon as the swap is complete. Even if she aint too pretty on the outside, at least the engine will look good, hopefully run good too. Thanks for the input guys, its been a big help.
Matt K.
#358983 - February 01st 2010 6:20 pm Re: '78 Dodge 318 2-bbl to Holley 4-bbl swap [Re: keystonekid1978]
I went far off the deep end the other way to get 100% throttle actuation and used Lokar Kickdow, Throttle cable, Pedal (billet) and brackets. Yah it wasn't cheap and I (with my brother's help) modified a lot of it some more including making a custom bracket for the carb to pull the throttle from the front instead of the rear, but she works great! smile get 100% throttle travel and kicks down good as well as activates the nitrous limit switch only at WOT. Here's a pic:
Hope that helps some (yes, the cables aren't hooked up but you can see all the brackets)
Edited by Alikazam (February 01st 2010 6:23 pm)
1972 Dodge Van "Tigerlilly" - Blazing Copper/Sandstone Metallic - 3850 lbs empty
13.47 @ 97.53 mph N/A - 11.94 @ 113.33 mph N2O - old 360/727 + Nitrous (N2O)combo
Viper V10 + 4L80E conversion in progress...
12.307 @ 113.36 mph - best so far & 23+ mpg on the freeway
1 registered (1 invisible), 4 Guests and 13 Spiders online.
7776 Registered Users
newkirkinc1 131
HighwayStar 131
Reed 112
lukester 99
apo234 89
frscke1 81
cjhardcore 80
al55 78
Glitch 72
CatFish 63
7774 Members
67 Forums
29629 Topics
