color coded dash bulb holders
by Matman
3 seconds ago
my BRUBAKER BOX
by 77Quadravan
Today at 02:02 AM
by 77Quadravan
Today at 02:00 AM
by 77Quadravan
Today at 01:58 AM
Today at 01:49 AM
by nightdragon
Today at 12:46 AM
vent visor or rain gaurd
Today at 12:17 AM
Wookee
Today at 12:11 AM
by zank
Today at 12:10 AM
Today at 12:08 AM
Page 2 of 61 < 1 2 3 4 ... 60 61 >
#389358 - June 03rd 2010 9:17 am Re: Did some "glassin" Today [Re: vanman2]
Looks good so far. You gonna mold it all in?
#389680 - June 04th 2010 10:39 pm Re: Did some "glassin" Today [Re: Superbeast]
Going to try Ken grin Probly wont behind bumper,but the rest will B, Mite B some kinda body line but.....we will C,fiberglass is amazing! cheers
#389749 - June 05th 2010 5:02 pm Re: Did some "glassin" Today [Re: vanman2]
matchstickBGV Offline
Loc: louisville, ky
looking reallllll nice. I dig it heavy. keep the pics comin please.
#391029 - June 12th 2010 9:36 pm Re: Did some "glassin" Today [Re: matchstickBGV]
Worked 6-10 dis mornin,came home and did some more glassin! grin
Goter all ground up!
Wasent real happy witt how the corner was......so I took da cut off tool to it! grin
Then mix up some resin and cut up some mat and mixed it up,stuffed in hole,let set up then glassed witt some mat!
Not 2 shabby grin
Got some small like 1" 60 grit flap wheels witt 1/4" shaft and put in angle grinder! work real sweet on close curves!! Glassin is like sheet rock.....the worse part is da sandin!! rofl
Amazing how bondo holds up when put on right,I molded(1/2 arse)flairs on in like 1980-81? and it held up all these years! just never got around to finish it!
Slaped some primer on it,going to give it a few more hours in mornin,going to try other side! cheers C ya then grin
Edited by heavy389 (June 13th 2010 11:57 am)
#391073 - June 13th 2010 12:05 pm Re: Did some "glassin" Today [Re: heavy389]
Did pass/side today grin
Ground it up
Laid some mat grin
Took care of the dimpples/spot welds,that R left from tack welding floor to outer skin while here,did otherside ,they were worse!!!
took some strands of glass mixed witt resin and put in after grinding out,and treatin rust!
Will hit them witt sander when doing outter sandin!!
Time for a cold one and pool right now!!!! More 2 come!!
#391348 - June 14th 2010 2:30 pm Re: Did some "glassin" Today [Re: heavy389]
Looks good so far. Will the mat be enough to hold the dam on or is there other mounting besides the 2 screws?
#391461 - June 14th 2010 8:32 pm Re: Did some "glassin" Today [Re: Superbeast]
That is just 2 of the 10 screws grin
When U say Dam...meening Roll Pan? If so she's screwed,glued,and a few layers of matting,I dont think its going anywere,I had it on before just screwed across back and 2 you see in pic,and it was glassed on sides & were it touched flairs Ken,It worked fine then,I had to use stright cut off tool to cut it off when I took it off to put tralier hitch on.So all that attaching and the matting I dont see any wind resistinace problem grin
#391581 - June 15th 2010 7:27 am Re: Did some "glassin" Today [Re: heavy389]
lol Yeah, that's it! That's what it's called crazy
Had a brain fart. So it does have more screws holding it on. I was just wondering if it would be strong enough to just glass it in place. Still Learning grin
#404199 - August 10th 2010 4:42 pm Re: Did some "glassin" Today [Re: Superbeast]
Had a little spat witt boss today an told em C ya tomarrow! So had chance to do some more on van,have been neglecting it 4 a few months,have a boat in a slip on bay and have been fishing every sat & sun 4 past couple months!!! So I saw today as a chance !!
Got a little bondo on
I use magic marker to mark low spots,its like ya dont wana waste no more bondo than ya need,takes lotsa layers of it to get all the low spots so this helps just puttin it were ya need it,most gets grated off and ends up on ground anyways! lol
After a few puddys!
After around 3 hours I called it quits and jumped in pool!!
The black is a rust encapsulator stuff I got from Eastwood,when ever I finish I spray it on all bare metal,then some I would spray primer right over it while it is still wet!! fills almost like a Nitro Stain puddy!! The primer will show ya were ya need more puddy too!! I need to do a little more work on lower flair area ya can C !! Well more next time!
#404204 - August 10th 2010 4:57 pm Re: Did some "glassin" Today [Re: heavy389]
Loc: louisville, ky
Looks reallll good as always man. I dig it. keep the pics comin!
0 registered (), 3 Guests and 51 Spiders online.
6694 Registered Users
Wizard78 373
frscke1 337
Uncle_Fester 243
NateNCBV 212
Lee7673 177
26236 Topics
