by Dodgecamo
6 minutes 11 seconds ago
17 minutes 53 seconds ago
28 minutes 23 seconds ago
Who owns this van?
38 minutes 26 seconds ago
by HomeBrew
59 minutes 41 seconds ago
Today at 03:58 PM
Hello from the UK
Today at 03:32 PM
Today at 03:31 PM
Today at 03:05 PM
My First Van Project
by Steel_City_Stax
Today at 02:58 PM
Page 14 of 18 < 1 2 ... 12 13 14 15 16 17 18 >
#451423 - March 06th 2011 4:12 pm Re: Engines - Triton vs Vortec [Re: Knightjp]
M_S Offline
Loc: CA
Originally Posted By: Knightjp
All valves are over the heads....
Mmmmm, no, they're not.
#451488 - March 06th 2011 9:03 pm Re: Engines - Triton vs Vortec [Re: Knightjp]
fatvanman Offline
Loc: Now in Emmett, ID
OHV as the Chevy chart does mean overhead valve, but it is meant to also indicate the camshaft in still in the block, while the Ford lists SOHC for Single Overhead Camshaft.
I do have one question - If you're going to all the trouble to do an engine swap, why would you consider the 5.3 instead of the 6.0 when the engines are the exact same external dimensions, the electronics are the same, etc. For the money you spend it will SPANK your other options. Just my opinion.....
Colin
aka "Fatvanman"
#451551 - March 07th 2011 12:49 am Re: Engines - Triton vs Vortec [Re: fatvanman]
Knightjp Offline
Loc: Dubai, United Arab Emirates
I wanted to compare the two... 5.3 is so much more closer to 5.4 than 6.0... lol
Besides, if I did a comparison of 5.4 vs 6.0... Surely the performance of the 6.0 will be better.
But I'm not just looking into performance.. I'm also looking into maintenance... I'm looking for issues with the engines that people have had with them.
I understand that there are quite a number of issues people have had with both engines.... But most issues seem to isolate themselves to their particular units, rather than the engine design.
I'm looking for the ones that hold on as actual design flaws... And I bet that even though there are fans of either engine, they will admit to something being a flaw in the engine's design.
#451563 - March 07th 2011 4:18 am Re: Engines - Triton vs Vortec [Re: Knightjp]
Knightjp Offline
I'm a little confused though....
The GMC site called the torque comparison a GMC advantage...
Is 334@4500 more low down torque or 350@2500 more... ?
Does anyone have an answer for the above question??.. This left me confused.... I always thought low down torque meant (more@less-rpm)
If that is true, then shouldn't the 5.4L Triton have the advantage??? 'Cos that's what the comparison chart shows...
Edited by Knightjp (March 07th 2011 4:20 am)
#451637 - March 07th 2011 10:55 am Re: Engines - Triton vs Vortec [Re: Knightjp]
fatvanman Offline
Max torque at such a low RPM means this engine doesn't have a wide RPM range at all, rather like a diesel. It would mean choosing your gear ratio's very carefully as you don't want cruising RPM 500RPM past max torque. If you are always towning then that would be the better choice, but for everyday driving I would rather sacrafice a bit of lower range torque for a wider performance envelope and wider torque range. So the Triton would have a 16 lb.ft but the Vortec 5.3 would have more torque over a broader RPM range making it perform better overall.
Colin
aka "Fatvanman"
#451688 - March 07th 2011 2:30 pm Re: Engines - Triton vs Vortec [Re: fatvanman]
Knightjp Offline
Originally Posted By: HiFlow5 0;6878238 from Automotive Forums / 5.4 Triton vs 5.3 Vortec
I don't have any experience with the Vortec motor, but I had a 99 F150 with the 5.4 Triton V8. That motor was great and had a ton of torque. I was able to move a 40 Yard dumpster sideways and into position in my driveway. The dumpster was half full of shingles and roofing waste and the truck moved it with ease. I was getting about 14 MPG, it was my daily driver for 3 years and I didn't have to do anything other then regular oil changes on the motor for maintenance.
Here is a good report for the 5.4 Triton. It seems that the torque range was pretty good and this guy didn't face problems...
Does anyone have a similar testimonial for the 5.3 Vortec???
#452211 - March 09th 2011 4:12 am Re: Engines - Triton vs Vortec [Re: fatvanman]
Knightjp Offline
OK... I'm a little confused.... if an engine produces more torque at a higher rpm, then that means it has a better range of torque???
I'm also confused that the Triton would produce more low end torque over the Vortec with the Vortec being a pushrod. I know pushrods are supposed to have more low end torque.. or is that all down to tuning???
the 5.3 Vortec in the Tahoe's & pick-ups uses a taller intake than passenger cars giving it much better low end torque at the expense of top end HP. That is what you would want to use in a van anyway, and should be the specs you are comparing. They should be pretty spot on with the 5.4 Triton, if maybe a little higher. But again, I mainly reccomended the Vortec due to better availability, lower parts costs, and narrower size to aid fitment since upgrading performance isn't a priority to you. But that same upgrade ability means you have more options as well.
You did mention that having more low end torque is a better deal for a van. Or should I consider sacrificing some low-end torque with the Vortec..
#452271 - March 09th 2011 10:27 am Re: Engines - Triton vs Vortec [Re: Knightjp]
M_S Offline
Loc: CA
Pushrods more low end torque? Where did that rubbish come from?
There is nothing you can divine from a max tq number made at one rpm vs another w/o seeing the chart other than one made more max tq than the other.
#452272 - March 09th 2011 10:36 am Re: Engines - Triton vs Vortec [Re: M_S]
Knightjp Offline
#452275 - March 09th 2011 10:52 am Re: Engines - Triton vs Vortec [Re: Knightjp]
fatvanman Offline
I wasn't suggesting that one design has inherent advantages over another as there are too many variables that can affect the outcome. However, overhead cam design generally will have the advantage in max RPM due to the reduced reciprocating weight of it's valvetrain, and a large majority of engines employing that design take advantage of that. And since that used to mean a drop in lower RPM torque (prior to variable valve technology) I can see why some have that impression.
Now, back to KnightJP's last comment - yes. A van would be better off with more low end torque, so a high rpm screamer isn't the best idea. In comparing the specs you gave for the Triton and Vortec, the Triton displays a small advantage in maximum torque, but by the listed RPM one can infer that the power falls off rapidly after that. The Vortec has a slight disadvantage in max torque, but by the numbers you gave showing the higher RPM, the Vortec is building torque over a wider RPM which in my mind offsets that difference. Of course either engine can be modified to suit whatever your needs are, but you stated you wanted stock comparisons. And again, I am only offering one opinion based on limited info. Take what you will from it. Both engines are very well designed and will last a long time. And either one should suit your needs. The question at that point becomes simply which one you'd rather see under the hood?
Colin
aka "Fatvanman"
1 registered (black79gmc), 3 Guests and 87 Spiders online.
Uncle_Fester 317
Wizard78 308
NateNCBV 236
frscke1 207
Lee7673 138
keystonekid1978 123
newkirkinc1 114
Dodgecamo, erichitscar, elmonoverde, jimmyn141, TheWhiteKnight83
6619 Registered Users
6619 Members
25962 Topics
