by vanfun
by pirate
just like to say thanks
my BRUBAKER BOX
by josh_performanceinc
by Reese
08:21 PM
08:17 PM
custom clocks by nightdragon
08:13 PM
by Phoenix
08:12 PM
Page 28 of 29 < 1 2 ... 26 27 28 29 >
#509596 - November 04th 2011 12:45 pm Re: update on my 87 g20 [Re: Bruiserman]
The side walls blow out
#509624 - November 04th 2011 2:01 pm Re: update on my 87 g20 [Re: Bruiserman]
Bfg's street tires maybe blow out but not the offroad tires...Ive beat the crap out of Bfg's & they take a good lickin..9 ply on the face and 3 ply on the side walls...I always run bfg's if they are good enough for the BAJA its good enough for me....if you run any tire low on air they all will blow out the side wall...Ive never had a problem with them
Edited by frscke1 (November 04th 2011 2:03 pm)
#509625 - November 04th 2011 2:02 pm Re: update on my 87 g20 [Re: Bruiserman]
i never liked the bfg's either, they have a smaller letter, small stuff i know... And every set ive had wear out very quickly. I like the cooper cobra's, but the futura's are so far a great tire for the price. 82 bucks a piece for 275/60's
#509807 - November 04th 2011 11:07 pm Re: update on my 87 g20 [Re: Bruiserman]
GhostRyder Offline
Loc: Land Of Entrapment, New Mexico
I never had any problems with the bfg 275/60 15's i had on a chevy pickup
David
GhostRyder
Do you believe in ghosts?
1981 Chevy G20 "Sanitarium"
http://s520.photobucket.com/albums/w321/mudslinger2006/
#509964 - November 05th 2011 8:41 pm Re: update on my 87 g20 [Re: GhostRyder]
Bruiserman Offline
Loc: Winter Garden Florida
I'm not worried. With the number of BF Goodrich tires out there and the fact that I've never seen or heard of one failing seems to me that it is highly unlikely. As long as they are holding air I'm quite happy. cheers
#510514 - November 08th 2011 10:05 am Re: update on my 87 g20 [Re: Bruiserman]
I have a set here that are now on there 4th vehicle.
this set are the same size so I can rotate them.regularly.
I have always had good luck with them.
Just like every thing else different people like different things.
It has also been close to 7 years since I have had to buy any new tires....
#524671 - December 29th 2011 10:40 pm Re: update on my 87 g20 [Re: Bruiserman]
Bruiserman Offline
Well,finally checking in after a busy few weeks. Made a change or two, more for function since my doors were stuck. The wood I put in originally was a bit thick. Found some real thin wood and stained/sealed it. Not sure where I'm going with it so it's all up in the air. May do more wood or go back with white. For now it's all about the doors working correctly since it's my daily driver. Not because it has to be but because I just love driving it.
#524690 - December 30th 2011 12:06 am Re: update on my 87 g20 [Re: Bruiserman]
looks good! I was wondering where you been. Good to have ya back. The wood looks good.
#524714 - December 30th 2011 7:47 am Re: update on my 87 g20 [Re: Bruiserman]
Goose111 Offline
Loc: Werl, Northrhine-Westfalia, Ge...
Looks nice, and I understand the problem.
On my previous daily driver, their was a little bit (big hole) corrosion on the passenger side in the step, and to make it cheaper, the corrosion was cut out and the replacement part (which didn't fit very well) was welder in.
The rubber from the door was so tight, that the paint was worked away and it start corroding again, this time the new part.
For the Hihgway, I have antislip aluminum parts with some red led's mounted in. I only need to find the time to remove the rubber-pad, make some corrosion-prevention and install the aluminum parts.
#524962 - December 31st 2011 12:00 am Re: update on my 87 g20 [Re: Bruiserman]
Looks great.
1 registered (1 invisible), 2 Guests and 84 Spiders online.
6694 Registered Users
Wizard78 373
frscke1 335
Uncle_Fester 253
NateNCBV 212
lukester 194
Lee7673 181
26232 Topics
