#509657 - November 04th 2011 3:27 pm
Re: 318 Re-Assembly Sequence - Timing Cover/WP
[Re: Grogan14]
Loc: Joyce Washington
Go ahead and install the timing cover AND the water pump before stuffing the engine back in.You'll just have to play with the bolts to get the right lengths in the right holes,some are fairly obvious and if you get a wrong one in just try another.Try a dry fit to figure it out before installing gaskets and RTV,any that will need removing to install a bracket later on should be ok as the RTV(which will have set up)and other bolts will hold everything together without disturbing the seal.Good luck
#509735 - November 04th 2011 8:29 pm
[Re: heavy389]
And if you had the pan off it makes it easier to get a good seal with the pan gasket also sealing the bottom of the timing cover.
#509752 - November 04th 2011 9:09 pm
[Re: Grogan14]
 I have had my timing cover off twice. The first time I wish I had more attention to which bolt went where, and the order which the brackets/ accessories must go back on. I did several dry runs before feeling confident enough to use the RTV and committ. The second time I pulled each bolt from a piece of cardboard with a general sketch of the bolt hole pattern but still did not write down the order of removal and wound op doing a dry run or 2 as well, and using gasket glue to hold the gasket to the cover, because I messed that up the first time. The bolt holes which penetrate the water jacket, smear the threads with RTV, and let it cure somewhat before refilling the block with coolant. These are common sources of coolant leak In my experience. I also have 2 bolts which keep loosening up and start leaking slightly, and need to bust out a 9/16 open ended wrench every 3 weeks or so. One time I smeared the outside of the bolt heads with threadlocker red, and got 2 months before retorque was required. You're not reusing the water pump are you?
#509753 - November 04th 2011 9:13 pm
[Re: Grogan14]
Man, you need a garage or a shop to assemble the engine. CFleanliness is next to godliness. Small blocks are really forgiving just keep it clean. You need to get the Mopar engine assembly guide /or the engine book. There are step by step instructions to assemble a small block mopar engine. Good luck
#509762 - November 04th 2011 9:38 pm
[Re: wrcsixeight]
Loc: Live Free Or Die
You're not reusing the water pump are you? Thanks for the reply, wrcsixeight! No, new water pump and timing set. Also, new main and rod bearings, rings, camshaft, cam bearings, lifters, oil pump, freeze plugs, gaskets.
1 registered (Nimrod),
8
82
6599 Members
25909 Topics
