#468961 - May 20th 2011 1:50 am
Re: Want kind of gas mileage do you get.
[Re: VanInFlorida]
Would a Dodge 4 cylinder really move a full size van?
#468982 - May 20th 2011 6:47 am
[Re: VanInFlorida]
The biggest 4-banger that Dodge built was the old 2.5L they put in the minivans and K-cars.
I highly doubt this engine would have enough HP to move a full-size van. Even turbo-charged I just don't think there'd be enough low end torque.
V6 or Slant six at a minimum.
#469012 - May 20th 2011 12:21 pm
[Re: VanInFlorida]
That's what I was thinking.You would end up over working the motor,defeating the gas savings.I really liked the 3.9 v6 that was in my old Dodge.More power then my 3.7 225 and it was fuel injected.Both get great mpgs for a full size van.
#469047 - May 20th 2011 4:52 pm
[Re: Tang]
I'm gonna put a 4bt/3.9l cummins diesel in my Dodge. just lookig for the right bread truck to pull it from. These are a turbo 4 cylinder. Bread trucks are pretty big,so I guess it would work in a van.Here is one on Ebay
#469380 - May 23rd 2011 2:00 am
[Re: Tang]
Loc: Orlando area, FL
I'm gonna put a 4bt/3.9l cummins diesel in my Dodge. just lookig for the right bread truck to pull it from. These are a turbo 4 cylinder. There you go, I bet you'll get 30mpg. Just think, if you do some research I bet you could even run that engine on used deep fry oil/bio diesel and have the best smelling van in the neighborhood.  I was thinking of using a 4 banger out of one those little D-something mini pickup's that were around in the early 80s. It was a rear drive truck so I'm hoping it would bolt up to an over drive automatic transmission from a newer car. I would sacrifice high performance for good gas mileage, don't need a Van that runs 0 to 60 in 6 seconds, if it gets there in 10 to 12 seconds, that will be fine with me. I live in FL so I don't need mountain climbing power, a Van going down the road 55-65mph only needs around 60 horsepower max. 75 if the A/C is on.
#469452 - May 23rd 2011 12:25 pm
[Re: VanInFlorida]
The 5-cyl Mercedes-Benz diesel in the old Sprinters moved those big boxes around pretty good. I wonder how one of those would work.???
#494267 - September 05th 2011 7:30 pm
[Re: VanInFlorida]
ive really considered this swap myself. If anybody does one, please post pics!
#509833 - November 05th 2011 12:47 am
[Re: VanInFlorida]
Loc: Pittsburgh, PA
Check out a 5cyl diesel mercedes engine and trans... Most are only four speeds but theyll definitely move a full size van. i have an 84 benz 300sd and its not quick but it would certainly move a full size... Best part is i get 32mpg
72 B200 /6 a833 4 speed
1 registered (Ram4ever),
69
6693 Members
26218 Topics
