#537016 - February 06th 2012 10:45 pm
foam insulation removal?
Loc: OH parma
this is my first time posting anything, but i need help. I'm 16 and i have a 77 dodge van that is completly full of spray foam insulation.
the van needs body work but the foam turns out to be realy flamable. I'm afaid to do anything with it all in there. is there any chemical i can use to remove it. or anything i can do to make it easier to remove, aside from just scraping it all off?
#537031 - February 07th 2012 12:27 am
Re: foam insulation removal?
[Re: frscke1]
Welcome to the site. Before adding chemicals I'd recommend physically removing as much as possible through mechanical means. This tool will become your friend once you learn to use it, and can sharpen the blade yourself. Use it with the putty knife looking attachment. http://www.harborfreight.com/oscillating-multifunction-power-tool-68303.htmlBetter versions certainly exist. They get you on the replacement blades. I've beat this tool up pretty good and lent it out not expecting it back working right. Still does though
#537580 - February 08th 2012 6:50 pm
[Re: BradFinkle]
I had a beautiful 75 Dodge and it had sprey foam in it also and the great thing about spray foam is the you can sleep in the van until noon on a hundred degree day. It is like sleeping in a styrofaom cooler. The bad thing about spray foam is it will rust your van completely out from the inside out. By the time you see rust on the outside it is too late. The chemical that makes the foam... foam, is corrosive. kind of like throwing salt in a beer. My 75 was new when it got the spray foam and seven years later it was showing signs of rust so went through a restoration and new paint. within a year it was back and went down quick, By '86 I bough the Phoenix and by 89 had to retire old silver, the paint was the only thing holding it together. Just a word of warning and experience. be watchful.
#537703 - February 09th 2012 12:37 am
[Re: BradFinkle]
Thanks for that heads up Phoenix, I was considering foam in Wolf-Den. . . . guess not ! lol Any tips for a good insulation for my big girl ?
#537731 - February 09th 2012 6:43 am
[Re: BradFinkle]
Old Timer
Loc: Pittsburgh,Pa USA
I still use good old fiberglass!
Jim & Lucy Newkirk Three river vans 1981 Chevy-the Love Shack 1999 Chevy Van 2012 Chevy Van vanninvanner@comcast.net
#537844 - February 09th 2012 1:56 pm
[Re: BradFinkle]
The PINK PANTHER stuff?
#538337 - February 10th 2012 5:18 pm
[Re: BradFinkle]
Good tip Super Beast ! I would not have thought of that, until about 15 seconds too late ! lol
#544914 - March 03rd 2012 2:33 pm
[Re: Uncle_Fester]
Thanks for that heads up Phoenix, I was considering foam in Wolf-Den. . . . guess not ! lol Any tips for a good insulation for my big girl ? I used and have always used pink panther fiberglass and covered it with 1/4 inch plywood and always has worked fine. I just taped it to the ribs with duct tape and the plywood takes it from there. I do pull it apart for the roof because you cant cram 3 inch pink panther in a one inch space. but it splits easy. Good luck with the removal of the foam, I really hope you don't find a bunch of rust under it, if you do, close it up and find another van
Edited by Phoenix (March 03rd 2012 2:39 pm)
1 registered (Wizard78),
57
6611 Members
25974 Topics
