my 1995 Dodge project
by cerberus
2 minutes 27 seconds ago
Latest tuner trend. . . .
by Bryce
3 minutes 5 seconds ago
YOUR OLD LADY AND YOUR VAN
by quiet1
14 minutes 38 seconds ago
New to forum from WV
by cerberus
19 minutes 37 seconds ago
Come Over to.........
20 minutes 55 seconds ago
57 minutes 49 seconds ago
by nightdragon
Today at 01:28 AM
1975 chevy shorty
by 76ChevyVan
Today at 12:48 AM
Removing front door hinges 77 Dodge
Today at 12:47 AM
Something Great is Happening
by nautic1
Yesterday at 11:51 PM
Page 1 of 4 1 2 3 4 >
#539318 - February 13th 2012 8:48 pm Skipping
DrBob Offline
My 90 5.2 has started skipping off and on, more on today. Started skipping in idle today. curse Everything was new in the ignition last Sept. only @ 2000 miles since.
As soon as decent weather I'll pull the dog house. Hopefully tomorrow.
#539362 - February 14th 2012 1:36 am Re: Skipping [Re: DrBob]
Double Check battery cables and battery to engine/frame grounds.
Then look at the hall effect sensor/ distributor pick up under the rotor. This particular replacement part has issues with reliability sending the owner on a wild goose chase until they come back to it.
I have an Elchin from Napa that is still working 6 years later.
Also make sure all the connectors at the engine computer are tight, and not growing any white or green corrosion
#539370 - February 14th 2012 4:30 am Re: Skipping [Re: DrBob]
I believe you are referring to "missing" as in missing an ignition cycle on a cylinder here and there right? Make sure all your plug wires and rotor and cap all look to be in good shape. Moisture in any of that area can cause problems! smile My van wouldn't even fire once, just dried out the inside of the cap (found some moisture) and fired up like a champ and ran smooth as silk. Good luck!
#539420 - February 14th 2012 10:39 am Re: Skipping [Re: DrBob]
DrBob Offline
I think I found the Problem.
Opened the hood to check fluids and looked in side and am seeing a mouse nest on top of motor. will find out this after noon when it warms up.
Not the first time this has happened. they ate through the wiring on my Transport Burning the inside. Have found them in the air filter before, that's what I'm figuring now.
this is what I found
Seams to be running smooth now, I'll find out next time I go out.
Edited by DrBob (February 14th 2012 1:34 pm)
#539606 - February 14th 2012 6:39 pm Re: Skipping [Re: DrBob]
hey DrBOB I bought some mouse traps today need any? : smile
#539853 - February 15th 2012 11:11 am Re: Skipping [Re: DrBob]
DrBob Offline
Thought I had it but started missing again after it warmed up.
Will pull the doghouse again this afternoon when it warms up.
#539901 - February 15th 2012 1:20 pm Re: Skipping [Re: DrBob]
DrBob Offline
Ok did some testing and checking. could not find the cause of the missing till I pulled the air filter {NEW}. Now it seems to run ok.
I'll find out tomorrow when I go to store {beer run}. Any other Ideas?
Tuned up less thane 5000 miles. Dis cap & rotor look new.
#539935 - February 15th 2012 2:42 pm Re: Skipping [Re: DrBob]
Check the air intake hose and make sure there isn't a nest in there.
#539975 - February 15th 2012 4:21 pm Re: Skipping [Re: NateNCBV]
DrBob Offline
That's the first thing I checked I think the air temp sensor or the vacuum diaphragm isn't opening
#540211 - February 16th 2012 9:53 am Re: Skipping [Re: DrBob]
DrBob Offline
OK Froze my ass off going to store with no dog house.
Missed a couple of times while going to store 4 Miles.
Never missed a beat on way home.
I'll see if my vacuum pump is working after it warms up.
Have to run without top on breather to go to parts store, but putting dog house on.
0 registered (), 7 Guests and 83 Spiders online.
aftoyboy, brianrussell
Wizard78 285
Uncle_Fester 277
NateNCBV 256
HighwayStar 252
frscke1 216
keystonekid1978 138
Reed 137
Superbeast 113
newkirkinc1 99
anis, Dale38, mbernhardt, grider, POPS58
25908 Topics
