Roof Upholstery...
by MasonT
by Otis
3 minutes 34 seconds ago
Hi from Ontario, Ca
4 minutes 47 seconds ago
86 G20 1st Van Build!!
by MasonT
22 minutes 42 seconds ago
24 minutes 21 seconds ago
Hello from the UK
27 minutes 11 seconds ago
Dissatisfied Customer
Today at 01:46 PM
Today at 01:32 PM
Today at 12:59 PM
Rear breaks on a 2001 E350
by Superbeast
Today at 12:47 PM
#546462 - March 08th 2012 9:30 am Mounting a storage box to a fiberglass campertop - also triangle window seal...
honkytime Offline
Loc: on the road
Hi all...I'm moving into the next phase of my project and have found out that the roof vent placement on my new van is about 1ft different than my old van. This means that my storage up there needs to change. I have a cargo box and I need to now move it forward. I was hoping to mount it directly to the top with 3m super tape BUT there are very few contact points. I don't want to drill all the way into the camper to bolt through....
Sorry...no pics just yet
Also...anyone know if there is a cure for a leaky triangle window without replacing the weatherseal? the leak is so small...but it's there.
Sensa-Track front shocks
New coil springs
Firestone airsprings
3core rad
tranny cooler
Queen size upper birth
2 burner stove + oven
3 way fridge
16000btu/h furnace
-carries -
Yamaha Vino 50cc Scooter
9.5ft Mainstream Sound kayak
Sportrack Luggage box
====Shows=====
#546472 - March 08th 2012 10:10 am Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
Happy Birthday Uncle_Fester Offline
Tri-Angle window? Ummn vent window on the door? I have seen guys use 1/4 x 1/4 inch sticky foam weather stripping before with good results, No thicker than 1/4 inch or it will stress your mounting points too much and may break the frame work. . . .
#546489 - March 08th 2012 11:46 am Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
3m VHB tape is good stuff, but I don't think I would trust it for a cargo carrier at highway speeds. If you don't have enough connection/contact points, it is out anyway.
You are stuck with mechanical fasteners.
Use Stainless steel nuts and bolts with large washers to spread the load. Put a large dab of Dicor sealant under the washers.
#546508 - March 08th 2012 12:20 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: wrcsixeight]
honkytime Offline
Loc: on the road
yeah that was the tape I was thinking. Ok, what about a combo of the tape and limited fasteners that only penetrate the fiberglass top?
I know nothing of it's strength. Would a stud finder find the wood subframe? I don't have one but could get one.
Next thought..what about VHB'ing square tubing to the roof and then drilling into that? it would provide much more vhb contact (the width of the carrier
vhb marine board to the roof and then drill into it?
sorry for the barrage
New coil springs
3core rad
tranny cooler
3 way fridge
16000btu/h furnace
-carries -
====Shows=====
#546509 - March 08th 2012 12:22 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: Uncle_Fester]
honkytime Offline
Loc: on the road
yep..ok thanks for that. Do you know of a product that is good for rubber reconditioning?
New coil springs
3core rad
tranny cooler
3 way fridge
16000btu/h furnace
-carries -
====Shows=====
#546526 - March 08th 2012 1:57 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
believe it or not, I have use trans fluid or olive oil with some degree of luck. . . . . The ATF was by accident, but it turned out ok.
#547100 - March 10th 2012 6:54 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
honkytime Offline
Loc: on the road
Here is the space I am working with. On the back left in front of the rack bar. I think i am going to vhb and then screw it into the aluminum siderail.
New coil springs
3core rad
tranny cooler
3 way fridge
16000btu/h furnace
-carries -
====Shows=====
#569543 - June 19th 2012 12:08 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
XQJ_37 Offline
Loc: Colorado Rocky Mtn High
Any luck with the trianle window seals??? I am stuck with the same problem, expect mine are totally rotted out. Having a hard time finding replacements
#569547 - June 19th 2012 12:08 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
rubbing alcohol, and soak it overnight.
#569551 - June 19th 2012 12:23 pm Re: Mounting a storage box to a fiberglass campertop - also triangle window seal... [Re: honkytime]
I have gotten tri angle windows for others in the bone yard & mailed them off....need your yr & brand.....
2 registered (NDJarrett, 1 invisible), 3 Guests and 68 Spiders online.
Uncle_Fester 307
Wizard78 299
NateNCBV 230
frscke1 208
keystonekid1978 134
Lee7673 130
al55 125
newkirkinc1 112
MACE 107
PTOMomma, Mikemod63, cammyjee, sandalscout, jonnyray
6612 Registered Users
25976 Topics
