#548391 - March 14th 2012 6:09 pm
Re: Axle Flip Done - Coilovers or Air bags
[Re: BenDodge]
Loc: Fort Wayne, IN
My shackles are stock units flipped down (disconnected to get around filler neck, then re-attached downward). So, yes, the last photo has a taller ride height than the first by a few inches. A 3" C notch would keep you out of the floor pan, but may not be enough to keep the diff from hitting on hard bumps if that is your ride height during cruising. If you bag it and drop the floor onto the diff during parking, but raise it for driving time, that would be different. I also would worry about floor strength if you only have a 1" frame rail for that small section, it still takes a lot of movement and abuse during acceleration torque. I would advise notching through the floor and raising your floor pan up to the top of the notch rails, instead of the bottom. I wish I would have. That would allow me to relocate my shock mounts and keep the lower ride height without bottoming the diff on the floor. I hope that I can help you in this rather than raise more confusion. Just worrying about strength to keep the van and not fold it, or twist it..
How do you know it won't work? Have you tried it, yet?? Mad Anthony Vanners - Looking for more members
#551528 - March 26th 2012 8:32 am
[Re: Natural_State]
Loc: Providence Bay, Ontario. Canad...
Going to try and get the shackle done this week. I concede with a 3" notch its prob not enough travel. So have been looking at air bags. FIRESTONE kit mounts between the rail and bolted to axle inside of the leaf spring. I prob dont have enough clearence at this location to squeeze a bag in and have reasonable inflation to stiffen ride up, ie prevent bootoming out. AIRLIFT kit mounts outside of rail and bolts to leaf/perch. With the axle flip may need a custom mount to axle. Notsl sure if top kount would foul the c notch. What about mounting bags behind the axle, not over. Or even inside the frame between the pumpkin on each side. I would gain space for the bag and declutter the cnotch axle area.
Edited by BenDodge (March 26th 2012 10:38 am)
#559699 - May 01st 2012 9:44 pm
[Re: BenDodge]
Loc: Toledo, ohio
So I bought a 2 inch block kit from autozone today. I was planning on flipping the axle on my 91b350 I'm not welding anything or spending a ton of money on my van because its a rot box. Would it still be drivable?
86 Lincoln mark VII (n2o queen) stock with 175hit 86 Lincoln mark VII (migraine) 351w, built aod, coil conversion, gear 91 Dodge B350 (party bus) 318,auto, flinstone mod
#559700 - May 01st 2012 9:47 pm
[Re: BenDodge]
Loc: Toledo, ohio
What I'm asking is should I opt for the "lowering shackle" kit from AZ, or a block and flip kit? I'm looking for just an off the shelf deal for cheap..
3 registered (Uncle_Leon, kawrider, 1 invisible),
6
52
6611 Members
25975 Topics
