just bough this baby...
by zombie72
New from SoCal
26 minutes 15 seconds ago
38 minutes 56 seconds ago
43 minutes 41 seconds ago
51 minutes 58 seconds ago
Yesterday at 11:20 PM
Yesterday at 09:37 PM
Yesterday at 08:53 PM
Yesterday at 05:29 PM
Yesterday at 04:37 PM
#553294 - April 02nd 2012 1:09 pm Silence when ignition turned.
cjhardcore Offline
Loc: Lakewood, WA
Not a dead battery, checked that but had to run to work.
When i get home, what should i be checking first. I know that i have a whole mess of things that need work on the electrical side of things (half the guages in the dash do not work).
I have a tester and the diagrams but which way do i start working from...the battery towards the starter and onto the ignition or is it vice versa?
#553363 - April 02nd 2012 4:51 pm Re: Silence when ignition turned. [Re: cjhardcore]
First thing I would do is run a ground wire over to the starter relay and see if it starts. If it does, you may have a bad neutral safety switch. The safety switch provides the ground for the starter relay.
#553429 - April 02nd 2012 7:35 pm Re: Silence when ignition turned. [Re: cjhardcore]
86ed Offline
Loc: puyallup,wa
for the heck of it, see if it will do anything in neutral. when i got mine the linkage was messed up and i had to start it in neutral half the time. ended up adjusting the linkage and now mine is fine.
#553495 - April 03rd 2012 5:03 am Re: Silence when ignition turned. [Re: cjhardcore]
I had an issue like this once on my van and took some emery cloth and cleaned up all my contacts between battery and starter and grounds and viola! she started right up. Replaced the starter before I found out what it was... *sighs*
#553496 - April 03rd 2012 5:28 am Re: Silence when ignition turned. [Re: cjhardcore]
make that voila! smile dang typo's...
#553509 - April 03rd 2012 6:41 am Re: Silence when ignition turned. [Re: cjhardcore]
I thought you were playing the viola. lol
#553514 - April 03rd 2012 8:12 am Re: Silence when ignition turned. [Re: cjhardcore]
F350 Offline
Do the producere outlined in this thread:
http://www.vannin.com/threads/ubbthreads...html#Post553332
See if that solves the problem.
I think I need to make a sticky thread for the mid-dodge owners about the electric system on those rolling piles of misery.
0 registered (), 3 Guests and 83 Spiders online.
Metal_Skoan, SaabGuy
Uncle_Fester 318
Wizard78 311
HighwayStar 250
frscke1 200
Lee7673 144
al55 125
newkirkinc1 123
Ripper 122
keystonekid1978 114
6621 Registered Users
