Dodge 1989 fiesta XRT need camper electrical advice
Today at 11:10 AM
Sport Wheel Center Cap Bolts
by 87ChevyVan
Today at 11:00 AM
Couple junkyard pics.
by Capn Scurvy
Today at 10:52 AM
by Capn Scurvy
Today at 10:47 AM
Article on Jalopnic with van pics
by wookee
Today at 09:43 AM
Dream Vannin' Prospect - Input Welcome
by pirate
Today at 09:34 AM
rear window louver identification help
by Digz
Today at 09:25 AM
Custom Vanner Issue 8 out now!
by matchstickBGV
Today at 08:55 AM
Speaker buzzing when engine running
by Phoenix
Today at 08:30 AM
Page 42 of 82 < 1 2 ... 40 41 42 43 44 ... 81 82 >
#504556 - October 15th 2011 6:09 pm Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
Happy Birthday draggnastro Offline
Hell yeah!what good are fat tires if you cant roast em!
2003 Grand Caravan
#505407 - October 19th 2011 10:00 am Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
With the right cam/carb set up, trans and rear gear ratio you can make that 360 run strong sound great and get decent fuel mileage.
In a van a V/8 is the way to go........
........Wookee
#505417 - October 19th 2011 10:17 am Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
This 360 is in a 77 fury and has a 2 barrel and runs strong. Id love to see what it will do when he gets done with it
#505519 - October 19th 2011 2:47 pm Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
She's definitely gonna be a runner, im going to keep it fairly mild. May change the rear end gears in the future though to bring down the cruise rpm
2003 Grand Caravan
#505545 - October 19th 2011 4:33 pm Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
They put a low rear gear behind 6 popper to give them more power from light to light.4:11's are very common.
I don't speak Dodge very well so I can't tell you how to double check the gear ratio.
I do know a 3:08 to 2:73 will give you good Hi way operation and with a low end torque cam plenty of light to light power.
.........Wookee
#505669 - October 19th 2011 11:15 pm Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
I hope we get it pulled soon. Not to far from colder weather.lol
#505680 - October 20th 2011 2:10 am Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
Uh, 4.11 gears are NOT common behind a slant six. 2.9, 3.2 are the most common, 3.5 is third.
The gear ratio should be on the tag under the hood above the batter, or, if the it is still there, there was a tag attached to the rear axle on one of the cover bolts that has the gear ratio stamped on it.
#505745 - October 20th 2011 11:47 am Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
The 85 I had with a /6 had 3.55 gears. Rode along quite nicely with that setup. Wish I still had that van. frown
#505746 - October 20th 2011 11:57 am Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
I once had an 86 with a slant and 3.5 gears. It worked out to be a good combination. My brother's 83 shorty has a slant and 3.2 gears. It also is a good combination. My 83 shorty has a 318 and 2.7 gears. I would love to switch to 3.2 gears.
#505866 - October 20th 2011 10:08 pm Re: 87 Dodge "Southeast of Disorder" [Re: draggnastro]
I did say I DO NOT speak Dodge well.
I had a friend with a mid 76 Dodge.slant 6.The gear ratio felt way lower than a 3.5.The V/8 screamed at hi way speeds.
I guess I should have said it is common for GM to drop lower gear ratio's behind there 6's.3:36,3:73,4:11's where all available.
Sorry,I just do not trust tags and decals.
On a GM ring and pinion the gear ratio along with the rears build date is stamped right into it.
It takes all of the guess work out of what you have.
Just another reason to like a Chevy......
Depending on the rear set up in that Fury it might not be a bad idea to get the rear out of it......
there where also club member running 2:73 rears behind there 318's that where getting good gas mileage and decent performance out of the 2:73 equipped vans.
A good four barrel headers and exaust also helped out in this department.
That change seamed to wake those 318's up
.........Wookee
Edited by wookee (October 20th 2011 10:16 pm)
Edit Reason: added even more BS
Vantopia II
06-06-2014
2 registered (frscke1, mcjeep), 3 Guests and 19 Spiders online.
mattmccurry, CCLTD93, mray12, Jackson_Thousand, bigchopz
7751 Registered Users
HighwayStar 143
newkirkinc1 125
Reed 104
lukester 101
al55 78
cjhardcore 77
Glitch 77
frscke1 76
apo234 71
jules73 70
7752 Members
29583 Topics
