by redrooster
37 minutes 3 seconds ago
Beefing up front suspension
Today at 04:52 AM
color coded dash bulb holders
by Matman
Today at 03:26 AM
my BRUBAKER BOX
by 77Quadravan
Today at 02:02 AM
by 77Quadravan
Today at 02:00 AM
by 77Quadravan
Today at 01:58 AM
by nightdragon
Today at 12:46 AM
vent visor or rain gaurd
Today at 12:17 AM
Wookee
Today at 12:11 AM
by zank
Today at 12:10 AM
#558374 - April 25th 2012 3:06 pm I'm melting!! :)
honkytime Offline
Loc: on the road
So I noticed some time ago (don't remember if it was before I left or not) that I had some weird glue like substance coming out of this...
before I left Calgary in this van I had two fresh deep cycle batteries installed from a shop back home. Other than that there has been no change to the electrics.
But when I talked to an old guy around here he said that this blue wire...should not be that way because nothing should run back to the ignition. (Blue wire is running to the front connection on piece that isolates the house batteries.
This is the backside
Any thoughts? How would I test it? Lucky enough...I have a spare ;)
Cheers
Sensa-Track front shocks
New coil springs
Firestone airsprings
3core rad
tranny cooler
Queen size upper birth
2 burner stove + oven
3 way fridge
16000btu/h furnace
-carries -
Yamaha Vino 50cc Scooter
9.5ft Mainstream Sound kayak
Sportrack Luggage box
====Shows=====
#558390 - April 25th 2012 4:18 pm Re: I'm melting!! :) [Re: honkytime]
Looks like it got hot and melted the potting material. I have a brand new one of those too if you need one.
#558423 - April 25th 2012 6:20 pm Re: I'm melting!! :) [Re: honkytime]
I would definitely remove that blue wire. Is it supposed to be a 12V hot lead at all times? I would somehow tap this to the battery.
The stuff that's melting is just a heat sink material. Replace the module with a good quality one and keep that one as a back-up. I noticed it was only mounted with one screw; you definitely want it held down with two screws because the module relies on a good body ground to function.
#558430 - April 25th 2012 6:59 pm Re: I'm melting!! :) [Re: honkytime]
Astro Offline
Loc: Dresden, Maine
is that connecting to an isolator or a solenoid? (the device separating the house batteris)
90 Astro - "The Grey Ghost" - Haulin Ass, Not kids.
93 Safari - "Lunavan"
E-Z Vanners of Mass, Maine, NY, NJ, England and Finland!!
"No matter where you go, there you are."
"If you can't do something smart, Do something right"
"There are three kinds of people in the world, those who can count, and those who can't"
#558434 - April 25th 2012 7:18 pm Re: I'm melting!! :) [Re: honkytime]
Eddie G Offline
Loc: a location near you ; )
Nate said Tap HEHEHEH
In Memory Of Eddie G Sr.
1/13/47 - 1/7/09
Vanimals 2% 1974/VCVC Member
1969 Chevy Van-"Runnin On Empty"
1976 GMC-"Fool's Overture"
1996 Ford E-150-"Heavenly Father"
OH-MY!!!
smile
Certified Van Judge
#558446 - April 25th 2012 7:58 pm Re: I'm melting!! :) [Re: NateNCBV]
The lack of a good ground, two screws, COULD be causing it to have a larger draw, causing the melt down described. . . .
#558469 - April 25th 2012 9:11 pm Re: I'm melting!! :) [Re: NateNCBV]
honkytime Offline
Loc: on the road
Thanks, that pic is after I started the removal. It is held on with two screws.
The clip that the blue wire goes to is an interesting blue clip. It was there when I bought the van so I'm reluctant to change it up.
New unit is solid and it corrected the issue with my headlights resetting the stereo when I turned them on.
New coil springs
3core rad
tranny cooler
3 way fridge
16000btu/h furnace
-carries -
====Shows=====
#558470 - April 25th 2012 9:12 pm Re: I'm melting!! :) [Re: Astro]
honkytime Offline
Loc: on the road
Isolator
New coil springs
3core rad
tranny cooler
3 way fridge
16000btu/h furnace
-carries -
====Shows=====
#558511 - April 25th 2012 10:30 pm Re: I'm melting!! :) [Re: honkytime]
You might consider removing it from the firewall for a min, sanding the area around the screw holes to clean bare metal, and remounting it, that way it has good clean ground points again. . . . just a thought. If you do this, just sand a tiny area, and add some dielectric grease ( available at MOST auto parts stores ) to protect against rust AND form a better ground.
#558597 - April 26th 2012 7:30 am Re: I'm melting!! :) [Re: honkytime]
That blue thing is a quick-splice connector. If you don't want to remove it, then wrap some electrical tape around it to keep moisture out.
0 registered (), 3 Guests and 59 Spiders online.
6694 Registered Users
Wizard78 365
frscke1 337
Uncle_Fester 243
NateNCBV 212
Lee7673 177
26236 Topics
