#499141 - September 23rd 2011 11:04 am
Re: Did some "glassin" Today
[Re: Superbeast]
OK, I'm still learning about this glass stuff. I like the woven mat stuff, but what about that other stuff that looks like flattened cotton candy? Are there pros and cons to each type of mat? Why would you use one type over the other. I can see pros and cons now over the different weights of mat. Mainly for shaping. If you lay the mat down and then spread the resin on it, how do you get that nice smooth outer surface that parts have? Lol That nice smooth outer surface is the 1st step Ken,If you are gel coating it gets sprayed on mold 1st,then the layers of resin and cloth,the stuff that looks like smashed cotton candy as U say Im thinking its "core mat",it is used to get a thickness,instead of a bunch of layers of mat me thinks,have never used it,would like to find some local but haven't been able to locate,an don't wana take chance on mail ordering it.I'm not gel coating so after the PVA is sprayed on I roll resin on it,then 10oz fine woven cloth (gets all bends an curves,body lines etc)then I used 2 layers of 20-24oz woven cloth,after that drys I put on 2 more layers of the 24oz stuff,and lay inner wood frame in wet door,then I put some cut to fit pcs of 2x4 were latches and struts mount,then glass over the frame & pcs. Got some pics coming tomorrow afternoon,rainin cats & Dogs rite now,and back is kickin....time for heat pad! >>>>>>
#499177 - September 23rd 2011 1:08 pm
[Re: Superbeast]
Cool! Thanks. Do you let each layer dry first or is it all done while wet? If done wet, I guess you need to work fast so resin doesn't harden before you are done. The 3 layers I just did on door was done in 1 mix of resin,lost about 1-1/2pts it started settin up,once it starts it dont stop!! I mix 1-gal resin w/1+1/3oz hardner and get like 20-25 mins work time! the hotter it is out the less hardner,and colder needs more!When it starts to set up it looks like jello
#499206 - September 23rd 2011 4:29 pm
[Re: heavy389]
Looking great.Thank you for posting pictures and sharing this great info......
#499486 - September 24th 2011 6:38 pm
[Re: lukester]
K worked on door somemore,brought camera in to unload some pics so.... k got the 3 layers of cloth on mold...  Let that setup,then put another layer on....  Then wet that out.... The PVA stuff works perty good,you can C how it makes a film like on mold...  Cut edges some....   Did some sandin on edges....  laid frame in to check fit.... Lookin fairly good  Now to clean up some mess......  Will post somemore pics when I glass the wood inner frame an stuff in>>>>>>> I think im going to pop it loose from mold before I glass inner wood frame in me thinks,mite come loose little easyer from mold I think!
#499612 - September 25th 2011 9:33 am
[Re: lukester]
Looking great.Thank you for posting pictures and sharing this great info...... Thanx Lukester!
#499694 - September 25th 2011 3:57 pm
[Re: heavy389]
great work & nice lil bug catcher.
Edited by lukester (September 25th 2011 3:58 pm)
#499722 - September 25th 2011 6:08 pm
[Re: lukester]
great work & nice lil bug catcher. Thanx, a guy gota patten on the Bug Catcher! Got a 2 liter bottle with little battery light in bottom,for catching them at nite,they drawn to lite and heat!!
6
68
25980 Topics
