#385762 - May 16th 2010 12:52 pm
Did some "glassin" Today
Got little close to snow pile in parkin lot and cracked front lower spoiler years ago,patched it witt some small alumin angle and pop rivets and "Road"!! Nice and warm out,good glassin weather! took air cut off to it  It cracked like this both sides same way!  glassed some mat on it  This is otter side glassed & prime   Now I gotta glass were this meets front flares,when I molded them together years ago it wasent a smooth line were they joined! 30yrs ago it was ok!  Next week maybe
#385811 - May 16th 2010 6:20 pm
Re: Did some "glassin" Today
[Re: nickrahn]
OUCH, I used to have a daily driver ...What am I saying they all were, even the Phoenix was for a short time about twenty years ago. Molded flairs and spoilers do not mix well with snow and a daily driver. espcially in your climate. Good luck with your fix, Just a hint from the guru of glass...J&J, use glass Mat instead of woven cloth it's stronger, saturate completely, work out all air bubbles, and don't get a drop of sweat in it, that spot will never cure.
#385839 - May 16th 2010 9:09 pm
[Re: Phoenix]
OUCH, I used to have a daily driver ...What am I saying they all were, even the Phoenix was for a short time about twenty years ago. Molded flairs and spoilers do not mix well with snow and a daily driver. espcially in your climate. Good luck with your fix, Just a hint from the guru of glass...J&J, use glass Mat instead of woven cloth it's stronger, saturate completely, work out all air bubbles, and don't get a drop of sweat in it, that spot will never cure. I try to use mostly mat,its very easy to work with and shape,the cloth is ok on somethings....I used mat & the heavy woven cloth on back sides for reinforcement,I used about 6 layers of mat and resin to build up 1/4" to edge of gullwing,I think it is alot stronger using mat
#388599 - May 30th 2010 2:02 pm
[Re: heavy389]
Long Weekend get to do somemore "Glassin" Whoooo hooo  Puttin rollpan back on   Moved it alittle from last mount!   Will grind er and matt er tomarrow  Glassin is perty easy I say,Its just the sandin and grindin  made a rig outs my stright shaft air grinder!  Took and put a wheel on then washer then nutter wheel and nutter washer and put it on,works perty kewl  Good for grindin down glass,just work it back and forth across area!!! thier was magic marker sayin Dodge...$32 on it from when I bought it bac in a day!!!  Must B gettin Old
Edited by heavy389 (June 01st 2010 9:38 pm)
#388628 - May 30th 2010 8:11 pm
[Re: nickrahn]
Old Timer
Loc: Pittsburgh,Pa USA
Looking nice.I'll be doing the same soon i hope.
Jim & Lucy Newkirk Three river vans 1981 Chevy-the Love Shack 1999 Chevy Van 2012 Chevy Van vanninvanner@comcast.net
#388735 - May 31st 2010 3:56 pm
[Re: newkirkinc1]
Loc: Leesburg NJ
Lookin good Heavy!
Josh Souders Performance Inc    The voices in my head may not be real, but they have some good ideas!
#388748 - May 31st 2010 6:01 pm
[Re: josh_performanceinc]
Loc: South Florida
Nice job man ~~~ keep us posted :
1 registered (SpaceTruckin),
37
25916 Topics
