#539495 - February 14th 2012 2:05 pm
Re: What Did You do To your Van Today?
[Re: wrcsixeight]
Cleaned Rat/mouse nest off motor top. Pics under Dodge forum. Had headlight go out last nite, changed that. {what fun, screws have never been out. Heat and Blaster.} Tightened up Battery turnamels.
#539519 - February 14th 2012 3:57 pm
[Re: wrcsixeight]
Loc: Leesburg NJ
DROVE IT!
Josh Souders Performance Inc    The voices in my head may not be real, but they have some good ideas!
#539541 - February 14th 2012 4:24 pm
[Re: wrcsixeight]
Loc: Northern Vermont
Fired my 87 4x4 Ford up and drove it around the yard a couple of times to check for anything odd in the drive line. Put it in 4x4 and locked the hubs... nice and tight! Nothing other than some tire rub from the 33s at full lock. Plates and inspection this week...sweet.
Then proceeded to the shop, had a safety meeting and stared at the 77 Dodge for an hour wondering where to start/ where to go from here....... totally at a loss.
  "GiVANtic" 1987 Ford E250 EXT 4x4 "Project Penny" 1977 Dodge B200 Shorty 8-0-2%
#539731 - February 15th 2012 12:00 am
[Re: wrcsixeight]
A new squeak developed from under somewhere. Today I found it to be coming from my fairly recently installed lower control arm bushings. I should have re torqued them at some point after install. I guess the teeth on the new bushing flattened out, or dug in, but I got nearly 7/8 more of a turn on both of the fine threaded bolts. SQUEAKICUS ENDICUS! Oh, here is what my previous LCA bushings looked like when I replaced them  BTW, Cherry, buy a newer 12 volt TV. Using an inverter to power a tv in not only less efficient, it causes a lot of inteference and many of the inbetween stations will be knocked out.
Edited by wrcsixeight (February 15th 2012 1:07 am)
#540035 - February 15th 2012 7:24 pm
[Re: wrcsixeight]
Loc: Georgia (the swamp)
Fought with my TPS screws, i think ford used locktite on em or they are just rusted in..gonna cut a decent flat head slot with the dremel tomorrow...Almost finished removing the old chipped paint from my wheel wells with aircraft remover..cant wait to finish em.
Edited by mrmattvan (February 15th 2012 7:31 pm)
94 Ford E150 4.9L inline 6 "Bad Company"
#541171 - February 19th 2012 11:39 pm
[Re: wrcsixeight]
 Captain Overkill
Loc: Myrtle Beach, SC
Drilled my wiper cowl to put the wipers back on,  And now that the motor is broken in and my leaks have been resolved, I put the engine cover back on and built a new drink tray. The engine cover was smoothed and the ashtray shaved.  The dash is done, except for the new radio mount. That'll come later. Also put a new shifter handle on.
#541177 - February 20th 2012 12:10 am
[Re: Boot]
I investigated why my High beams no longer functioned. When I disconnected the Dimmer switch, I knew I was onto something.  All fixed now. Also installed a new ignition switch.
#541187 - February 20th 2012 1:20 am
[Re: wrcsixeight]
Boot, your van stirs up inappropriate feelings toward it. That thing is gorgeous!
#541194 - February 20th 2012 2:36 am
[Re: wrcsixeight]
Boot, that sweety gets better and better every time I see it ! WOW does not begin to cover it !
6
38
6702 Members
26262 Topics
