New from SoCal
24 minutes 16 seconds ago
25 minutes 37 seconds ago
Today at 05:29 PM
Today at 05:12 PM
Today at 04:37 PM
Today at 03:16 PM
Today at 02:37 PM
by FinallyaVanner
Today at 01:55 PM
Today at 10:39 AM
by VanPLan
Today at 08:51 AM
#558974 - April 27th 2012 4:35 pm Not so good Vibrations
HomeBrew Offline
Loc: Ohio, USA
I drive the new early up the road last night to spray off the motor at the car wash....and Talk about some BAD vibration! No Joke - something was vibrating so badly, the Dash was shaking. Like REALLY shaking! I was worried the already broken windsheild might fall right out. Should have seen the look on Clovers face, LMAO. I wassnt going that fast either. 25-35 ish... Faster I went the worse it got. Granted the passanger tire was nearly flat, but I dont think it would have shook like that.
Trying to narrow down possible causes.
Wheel bearings? Tie-rod ends? King Pins? (I don't think there is a ball joint on these but will look)
If the drive shaft was not balanced, could it cause that effect?
Could bad Rear bearings cause that kind of vibration in the front?
I have not gotten it up in the air yet to wiggle stuff around, figured I'd ask about possible causes now so I can check all that when I do. (like this weekend....hopefully)
#558975 - April 27th 2012 4:41 pm Re: Not so good Vibrations [Re: HomeBrew]
My suggestions:
(1) Check the torque on all the lug nuts
(2) Check the motor and transmission mounts
(3) Check the u-joints/ball and trunion (if so equipped)
(4) Fill all the tires with air
(5) Get the tires balanced
(6) check for bent rim
#558983 - April 27th 2012 6:03 pm Re: Not so good Vibrations [Re: HomeBrew]
Lee7673 Offline
I am thinking motor mount or U-joint
#558986 - April 27th 2012 6:23 pm Re: Not so good Vibrations [Re: HomeBrew]
Im thinking a bent or out of balance drive shaft....
#558997 - April 27th 2012 7:02 pm Re: Not so good Vibrations [Re: HomeBrew]
If you have a tire seperating itll cause a bad vibration. Are they older tires and sat for a while?
#559005 - April 27th 2012 7:46 pm Re: Not so good Vibrations [Re: River_Rat]
well .......wutt was it??? rofl
#559008 - April 27th 2012 8:03 pm Re: Not so good Vibrations [Re: HomeBrew]
Drive shaft !!!! replace U-joints
#559613 - May 01st 2012 12:54 pm Re: Not so good Vibrations [Re: HomeBrew]
HomeBrew Offline
Loc: Ohio, USA
It had older tires. I replaced the front wheels, a little less vibration. I havent swapped otu the back yet. I noticed some horizontal and vertical play when I grabbed the wheel and wiggled it. But oddly my other early has a similar amount of play at the front wheel.
I pulled the motor and transmission on Sunday to swap it out, so I’ll be replacing the driveshaft and U joints in the process (shooting for this week/weekend - rain pending). New motor mounts on the way too. I hope it’s the shaft / U joints.
I did order a set of kingpins so I’ll have a set in stock if needed, should arrive next week. Clover is picking up bearings, tie rod ends, and any other parts he can round up. The plan is to have it road ready by Mothers Day weekend. One way or another. Tick-Tock…
#559806 - May 02nd 2012 12:12 pm Re: Not so good Vibrations [Re: HomeBrew]
You want almost zero horizontal/vertical play. Horizontal play could be worn out tie rods, or a drag link. Vertical play cold be loose wheel bearings or bad king pins.
New drag links are available through Rare Parts, P/N 25757. Can be purchased at Autozone.
#562257 - May 14th 2012 10:01 am Re: Not so good Vibrations [Re: HomeBrew]
HomeBrew Offline
Loc: Ohio, USA
I swapped out the drive line from the radiator to the back axle. no more vibrations horrible. BUT, there is a weird loud pop/clunk noise in the front end some times when turning. King pins arrived, so I'll order bearings, tierod ends, and drag links
2 registered (hotrod AL, strmstr69), 7 Guests and 51 Spiders online.
Uncle_Fester 315
Wizard78 292
HighwayStar 251
frscke1 202
Lee7673 145
newkirkinc1 125
al55 124
Ripper 121
keystonekid1978 114
6621 Registered Users
25980 Topics
