#560299 - May 05th 2012 3:31 pm
Re: Help in Laramie, WY area
[Re: nikothenomad]
Niko, since your pump is in the tank what I'm going to suggest you check before tearing things apart is not the most likely culprit, but if it pans out this idea would sure be more pleasant than dropping a tank...
Have you changed any in-line fuel filter(s)? Sometimes people have installed more than one in line between the tank and the engine. If they get filled up with water or are clogged you'll experience fuel starvation symptoms. A lot of times going up or down hills aggravates the situation.
It sounds like you may spend significant amounts of time parked. It's more likely that your tank will experience significant amounts of condensation inside when it's only partially full. If it's an option for you, it would be best to keep your tank relatively full when parked. The less air inside, the less moisture can condense out.
Edited by Ram4ever (May 05th 2012 5:04 pm) Edit Reason: confusing grammar
#560308 - May 05th 2012 5:20 pm
[Re: nikothenomad]
I'm glad you changed the filter, that was a great move.
A water-logged filter is often grade-sensitive; if there's lots of water in a filter, it will flow towards the low side while driving on a grade, which at least in the case of horizontally-oriented in-line filters does interfere with fuel flow; I've had it stop me dead going up hills. I've been more careful since then, and try to get filters which are clear enough that I can see into them. I also run dry gas through once in a while.
If a fuel line has a substantial low spot in it, water can pool there too. This is what often gets folks in cold climates when it freezes. I gather freezing is not much of a concern for you!
Do you suppose there might be a bunch of water or sludge in your tank?
My next guess for the most simple things to check would be the fuel filler cap. If it's vents malfunction you'll draw a vacuum, which will starve your engine of fuel. I'm not sure how that could be grade sensitive, but it's really simple to try. Just gently open the filler cap after experiencing the issue and if you hear a whooshing sound from air rushing in, a vacuum had developed in your tank.
When you had the fuel pump changed last time, do you suppose that there might have been a hole punched in the pickup tube? That would allow air to be sucked in. I've heard of corrosion making pinholes in pickup tubes too.
#560346 - May 05th 2012 10:44 pm
[Re: nikothenomad]
Almost wish I still lived in Laramie, you could park in my drive for days if needed, but alas I do not. BUT, on the NORTH side of town, there is a camp ground, they used to allow vans, school buses, ect to rent there. . . good luck!
It is behind the Pilot truck stop, and they have free wifi too, in the office area.
#560419 - May 06th 2012 5:11 pm
[Re: nikothenomad]
Okay, just a thought, but are you sure your float is not sticking? It could be sticking just enought to let you run when flat, but flood when on a tilt/ incline,......you can test this fairly easy, put a can of sea foam in the tank and run it out....this will clean out any gummy junk that might be sticking the float.
Remember, on a carved system, there are few parts, carb, filter, pump, lines, tank, and the fuel level float/ pick up tube. Start easy/cheap and go from there.
You replaced the inline filter, what about the brass one in the carb? Right where the fuel line threads into the carb. Careful, these threads are fine and delicate.
#560428 - May 06th 2012 6:05 pm
[Re: nikothenomad]
NIKO on my 90 there is a rubber line By the back axle that is for siphoning the gas tank. If yours has it there will be a plug on the end.
2 registered (jo123, apo234),
6
44
6702 Members
26261 Topics
