#561355 - May 10th 2012 12:23 pm
Re: Looking for some head......answers..
[Re: vanner71]
I keep checkin back to look for smart remarks.....  This new gas is junk on old motors Its called "octane"booster  Used to know guy that worked @ refinery years ago and he would get us gallons of what he said was "pure" octane! only put little in tank an you chitt ran like a raped ape! I left lid of a gallon next bay it was almost empty  had aalota alcohol or sumptin
Edited by heavy389 (May 10th 2012 12:26 pm)
#561371 - May 10th 2012 1:23 pm
[Re: woodchuck]
Loc: gettysburg, pa. usa
SEE your head is thinking about the wrong head.
#561425 - May 10th 2012 4:46 pm
[Re: heavy389]
I keep checkin back to look for smart remarks.....  This new gas is junk on old motors Its called "octane"booster  Used to know guy that worked @ refinery years ago and he would get us gallons of what he said was "pure" octane! only put little in tank an you chitt ran like a raped ape! I left lid of a gallon next bay it was almost empty  had aalota alcohol or sumptin I'm not going there
#561429 - May 10th 2012 5:16 pm
[Re: Wizard78]
I keep checkin back to look for smart remarks.....  This new gas is junk on old motors Its called "octane"booster  Used to know guy that worked @ refinery years ago and he would get us gallons of what he said was "pure" octane! only put little in tank an you chitt ran like a raped ape! I left lid of a gallon next bay it was almost empty  had aalota alcohol or sumptin I'm not going there LMAO
#561690 - May 11th 2012 5:08 pm
[Re: woodchuck]
Loc: Bristol, TN
Heat indicates it's running lean or the timing is off. Since it didn't get driven a lot for a while, it's very possible the advance in the distributor has corroded and not working properly. Check the timing as well, don't rely on the timing tab unless you know for certain that TDC on the tab is really TDC on the engine, I've seen these off as much as 10 degrees. I worked in an auto machine shop for about 5 years, I saw very few heads with the exhaust seats beat out because of unleaded gas, it was almost always due to an engine that already had excessive wear and the fuel/timing wasn't right causing it to run lean and the excess heat is what brought about the damage.
'85 GMC Shorty '99 AWD Astro '55 Chevy 150 ex-racer "I thought you weren't allowed to talk to guys with vans??"
#562518 - May 15th 2012 6:44 am
[Re: woodchuck]
Thanks will check timing .. The compression test prove that the seats are not the problem.. Plugs looked good when I pulled them.. Will be check distributor and timing next but still think that the gearing is the problem.. I got 3:23 gears and going to install around 3:90.. think that should do the trick... I hope.
#562520 - May 15th 2012 7:20 am
[Re: woodchuck]
Fred....3.90 and that engine will be screaming going down the road at 65 mph without overdrive. Personally I'd go with a 3.55 gear.
60
26235 Topics
