by BvrWally
24 minutes 17 seconds ago
New from SoCal
Today at 05:46 PM
Today at 05:29 PM
Today at 05:12 PM
Today at 04:37 PM
Today at 03:16 PM
Today at 02:37 PM
by FinallyaVanner
Today at 01:55 PM
Today at 10:39 AM
by VanPLan
Today at 08:51 AM
#564767 - May 25th 2012 7:36 pm which one best for heat insulation for cargo van?
Super_G20 Offline
Loc: Pillager,Mn
i am looking for put new heat insulation for cargo van but i dont know which one will work better?
#565216 - May 28th 2012 7:04 pm Re: which one best for heat insulation for cargo van? [Re: Super_G20]
I have used Owens-Corning Pink Panther for 37 years and 1/4 inch plywood. I leave an inch by the floor and an inch at te top of the sides to breathe. The top I split the 3 1/2 insulation so not to cram it full but still use a good sense about it. I always have good luck and good insulating results. I did have my favorite van ...75 dodge with spray foam insulation installed. the acid in the foam ate the van out from the inside out. By the time I saw rust on the outside ...It was too late. IOt however let me sleep till noon in 100 degree heat... like sleeping in a Styrofoam cooler, but not worth sacrificing your van for a couple years , then trashing it out at a salvage yard. I went back to the basics with the phoenix and am very happy with what I have. For the money opposed to the other stuff Aluminum coated blankets and all the other High tech stuff out there, this to me is the best way to go to me. Cheap and effective. just let it breathe, give it air so not to create condensation, as with anything. Think before you build.
Edited by Phoenix (May 28th 2012 7:08 pm)
#565295 - May 29th 2012 7:53 am Re: which one best for heat insulation for cargo van? [Re: Super_G20]
purplesporty17 Offline
Loc: spartanburg sc
i just installed "Reflexit" with aluminum tape which i got at Home Depot.
#565301 - May 29th 2012 8:18 am Re: which one best for heat insulation for cargo van? [Re: Super_G20]
MrHoney Offline
Loc: NY
When I did my 82 I used sheets of styrofoam just placed between all the ribs in the van and 1/4 inch plywood. It leaves a breathing space and does not absorb if any condensaion. Worked very well
shift
#565494 - May 30th 2012 12:15 am Re: which one best for heat insulation for cargo van? [Re: Super_G20]
Super_G20 Offline
Loc: Pillager,Mn
Umm what about Ez Cool? does it work good?
Moderator:  Snotty
2 registered (strmstr69, Sweet_Spot), 8 Guests and 64 Spiders online.
Uncle_Fester 315
Wizard78 292
HighwayStar 251
frscke1 202
Lee7673 145
al55 124
Ripper 121
keystonekid1978 114
6621 Registered Users
25980 Topics
