#565223 - May 28th 2012 7:35 pm
Re: Have An Idiot Light Lit
[Re: Cherry]
Loc: Eastpointe, MI ,yewessay
EGR light?
Those are setup to turn on after XX,XXX miles. It's to get you into the dealer for service.
Mine went on in my Dodge at the 75,000 mile mark. Funny thing was, I no longer had an EGR since I swapped intakes and carbs a year earlier.
Gregg Groff I am the wampeter of my karass.  68 ChevyVan 108 350/3 spd stick 86 Dodge "Yeah, it's got a 318" 08 Chevy HHR Panel Next generation of cool
#565232 - May 28th 2012 8:07 pm
[Re: Cherry]
If it's a yellow ck eng light then that has nothing to do with making it run hot.It's probably a sensor or just needs to be reset.
#565234 - May 28th 2012 8:24 pm
[Re: Cherry]
Depends on how crusty the bolt are.
I'd just plug the vacuum line and leave it alone.
And no, I am not aware of any way a defective EGR valve would cause overheating, it's just emissions junk. (Exhaust Gas Recirculation, it takes a portion of the exhaust gases and re introduces them into the intake. Makes your truck run lousy and get crappy mileage)
#565244 - May 28th 2012 9:58 pm
[Re: Cherry]
It is very very simple to use the factory engine computer to run onboard diagnostics and to pull the trouble codes. This will tell you why the computer turned the check engine light on. Instructions on how to run a self-test and pull codes are found HERE The terminals you want to use are found on the passenger side of the engine compartment around the battery. Explanations of the codes are found HERE
Edited by Reed (May 28th 2012 9:58 pm)
#565245 - May 28th 2012 10:04 pm
[Re: Cherry]
Loc: Dresden, Maine
you should be able to reset the light easy enough. I can do mine with a paper clip. you can also pick up a code reader at any local parts place, but I am guessing someone in your travels will have one. and I would go with what wookie said, disconnect the vacuum line from the EGR valve and plug it. and it won't have anything to do with temp, your overheating needs to be looked into and solved before it gets much warmer out or you could get stuck or do damage
90 Astro - "The Grey Ghost" - Haulin Ass, Not kids.93 Safari - "Lunavan" E-Z Vanners of Mass, Maine, NY, NJ, England and Finland!!  "No matter where you go, there you are." "If you can't do something smart, Do something right" "There are three kinds of people in the world, those who can count, and those who can't"
#565246 - May 28th 2012 10:05 pm
[Re: Cherry]
Loc: Dresden, Maine
yeah.. what reed said! lol
#565250 - May 28th 2012 10:36 pm
[Re: Cherry]
DO NOT DISCONNECT THE EGR VALVE LINE AND PLUG IT. The fuel injection system is designed to have a functioning EGR valve and it will not hurt performance if left in place.
Pull the codes and see what they are before you buy any parts or make any diagnosis. Overheating could be many things, including a failed sending unit. First thing I would do is pull the thermostat and make sure it opens right. Get a cooking thermometer and put the thermostat in a kettle of water and see at what temp it opens.
#565263 - May 28th 2012 11:43 pm
[Re: Cherry]
This van is NOT fuel injected it still has a carb. At least it still has a carb style fuel pump on the drivers side of the engine. My EGR diagnoses was because it is leaking exhaust and the donuts in the exhaust was tight. A bad EGR vale will do this
The van never made it to my place to pull the dog house cover.
........Wookee
62
25980 Topics
