by FinallyaVanner
the vannin documentary
by FinallyaVanner
by FinallyaVanner
by FinallyaVanner
by FinallyaVanner
03:02 AM
Dash out ?
12:37 AM
switching to power windows?
11:53 PM
11:38 PM
Blown Chevy
by Lordmodelbuilder
11:23 PM
by Hoagie
11:15 PM
#570722 - June 25th 2012 1:13 pm Leaky Thermostat Housing
strangeblue Offline
Loc: Chattanooga, tn
I changed out my water pump this weekend...
almost did my timing chain... but chickened out. (afraid I might screw something up.)
But anyways. I bought a new thermostat and rubber seal.
but everytime I start the car. It Leaks...
In between the seal and out of the screws...
I have tightened the screws as good as I can.
Do I need to use some liquid seal of some sort?
What to do??
Click for large view - Uploaded with Skitch
"Trade what you got - To get what you want"
1995 Chevy G20 Custom Choo Choo
Facebook Fan Page - click here to visit us
#571107 - June 26th 2012 9:59 pm Re: Leaky Thermostat Housing [Re: strangeblue]
First off, good job so far! I would clean that black stuff off the mating surface with a wire toothbrush, then a THIN coat of blue RTV around the mating surface of the T-Stat housing ( the dome part you took off), put it all together and DO NOT OVER TIGHTEN! I install mine with a 1/4 drive ratchet so as not to over tighten. Give it about ten min or so to "set up" before you start the motor.
This is how I do my t-stat swaps twice a year. I run a 160* in the summer, and a 195* in the winter. SEAMS to keep it cooler in the summer and better heat in the winter. . .
#571152 - June 27th 2012 7:26 am Re: Leaky Thermostat Housing [Re: strangeblue]
Bullet Offline
Loc: Bristol, TN
Is it just seeping a tiny bit or is it more than that? Clean the recess in the intake, get a good piece of 220 grit wet/dry sandpaper and place it on a flat surface, attach it some way, 2" tape all the way around, then put your thermostat housing on it and work it in a figure 8. Do this about 20 times and check the bottom, if it's warped you will notice some areas not touched by the sanding. Keep doing this until its nice and flat, you may have to use a couple pieces of sandpaper. If it's warped bad, you may be time and money ahead to replace it. It should seal with the rubber O-ring without using any RTV, but a thin, thin coat of sealer wont hurt anything. Don't over torque the bolts as this can cause problems too.
'85 GMC Shorty
'99 AWD Astro
'55 Chevy 150 ex-racer
#571196 - June 27th 2012 12:17 pm Re: Leaky Thermostat Housing [Re: strangeblue]
If the bolts thread into a water jacket, you will need some thread sealer on them.
#571215 - June 27th 2012 1:35 pm Re: Leaky Thermostat Housing [Re: strangeblue]
vanatic05 Offline
Vanaholic
Loc: Auburn IL
Also it looks like you have another gasket in the block still remove the old gasket...
Darrin Bentley
Director: Vanatics Van Club
92 GMC 3500 454/4bbl
roiboi65@yahoo.com
www.vanatics.com
#571306 - June 27th 2012 9:31 pm Re: Leaky Thermostat Housing [Re: strangeblue]
If you have a chrome housing they all leak until you take them to a belt sander and make them flat on the bottom... Just a thought , it is what I had to do.
0 registered (), 0 Guests and 87 Spiders online.
diamond dan
Wizard78 297
Uncle_Fester 293
HighwayStar 252
Lee7673 130
keystonekid1978 123
Reed 107
newkirkinc1 104
6605 Registered Users
6605 Members
25950 Topics
