Today at 06:38 PM
Without looking
Today at 06:17 PM
Who owns this van?
by Busykiwi
Today at 06:07 PM
by Busykiwi
Today at 06:03 PM
by Jimm
Today at 05:55 PM
Today at 05:26 PM
Today at 04:43 PM
Today at 04:32 PM
by HomeBrew
Today at 04:01 PM
Today at 03:58 PM
#571127 - June 27th 2012 12:08 am Microwave/AC not kicking on (Onan 2000)
ChrisPenn Offline
Loc: US
Hey guys, thanks for checking my post.
Key facts
-1990 Dodge B350 Xplorer conversion
-Radio stopped working 3 days before the Microwave stopped working
-Just changed the oil in the generator.
-Was out exploring around Sedona, AZ and did a little off roading, very bumpy
-Worked just after changing oil
-4-5k in elevation
-all breakers and fuses fine (Is there another fuse box besides the one in the glove box?)
The generator starts and runs fine. It almost seams to me that the switch that allows the microwave and AC to work after the generator has ran for a while no longer works.
Any ideas guys. I know nothing about electronics.
Chris
#571157 - June 27th 2012 7:48 am Re: Microwave/AC not kicking on (Onan 2000) [Re: ChrisPenn]
DrBob Offline
You should have Circuit breakers in there someplace. sounds like it's tripped. or U lost a ground someplace.
Edited by DrBob (June 27th 2012 7:50 am)
#571519 - June 29th 2012 3:21 am Re: Microwave/AC not kicking on (Onan 2000) [Re: ChrisPenn]
relaxedvanner Offline
Loc: Calgary Alberta. Canada
I agree with Bob. There must be a second breaker box or elect panel in the van. They must be splitting the power somewhere.
Shanning P.
Alberta, Canada
1991 Dodge Ram 250 Mark 3
Member of Vandits VC. Calgary
#571531 - June 29th 2012 8:22 am Re: Microwave/AC not kicking on (Onan 2000) [Re: ChrisPenn]
On most there is a panel inside near where the appliances are plugged in..there are also usually a diode or solenoid under the hood to charge the batteries....
97Errorstar,05 Freestar
Ottawa Valley Vans
Founder,Mixed Bag Truckers
#571574 - June 29th 2012 12:21 pm Re: Microwave/AC not kicking on (Onan 2000) [Re: ChrisPenn]
If any circuit breakers have screw terminals, make sure they're tight, and don't exhibit any obvious corrosion.
They can loosen even in a non-vibration environment... At the Space Command radars I worked at, we actually shut down our entire radar systems for one day each year to allow the Facilities personnel to go through the switch gear and every breaker box to torque each terminal to the manufacturer's specs. There were always a few which had loosened.
I even check the breakers in my house every couple of years. Over the years I've only found a couple which had loosened, and they were on the highest current breakers, such as my electric range and air compressor.
#572632 - July 05th 2012 8:45 pm Re: Microwave/AC not kicking on (Onan 2000) [Re: ChrisPenn]
ChrisPenn Offline
Loc: US
Cool, thanks guys. I am going to check everything and let you know what I find.
3 registered (mikehowell, Pokin'Panel, 1 invisible), 8 Guests and 89 Spiders online.
Uncle_Fester 317
Wizard78 306
frscke1 208
Lee7673 138
keystonekid1978 120
newkirkinc1 119
