by Alikazam
8 minutes 38 seconds ago
by smitty
33 minutes 14 seconds ago
D-Van GP
45 minutes 34 seconds ago
50 minutes 33 seconds ago
by c1run1
51 minutes 32 seconds ago
by c1run1
56 minutes 39 seconds ago
56 minutes 50 seconds ago
"YOUR" Vans thru the years!
Today at 10:08 AM
1976 Dodge - Window "Track" or "Anchor" Advice
by Steel_City_Stax
Today at 10:00 AM
#574488 - July 17th 2012 6:22 pm Remove fixed windows G30
phils Offline
Loc: Scotland
at some point i will have to fix my windows. they seem ok apart from the sections with the rivets which is rusting and pushing through the weather seal. anyone have a diagram of how they are fitted?
how do they come out, and where would i get a replacement weather strip?
1994 Chevy G30 LWB & 2001 Landrover Defender 90 Truck Cab
#574508 - July 17th 2012 8:38 pm Re: Remove fixed windows G30 [Re: phils]
there are no replacements ....drill out the rivets and make new alum plates and re rivet....
the only replacements are donor van....and if you break a window you will need a donor cause good luck finding a replacement window...
#574593 - July 18th 2012 3:03 am Re: Remove fixed windows G30 [Re: frscke1]
phils Offline
Loc: Scotland
AW FLUCK...
thats a nightmare, is there a universal weather strip you can use?
#574594 - July 18th 2012 3:14 am Re: Remove fixed windows G30 [Re: phils]
I had the '92 windows removed before I had it painted and the glass shop couldnt find it & either did I....had to clean them up. made alum plates gave them to the glass shop to reuse....the windows in the '93 I was quoted $3200 for a set of 2....you can get a donor van for that and have alot of spare parts....goood luck in your search...please keep me posted on your results....
#574595 - July 18th 2012 3:26 am Re: Remove fixed windows G30 [Re: phils]
That Gm site you sent me doesnt have the window #'s either...we have a rare breed van....not many made I ve seen 2 G20 with windows on Auto trader and they wanted a couple thousand but that is as much as just the windows....the only place I found them was Armortek in Texas...they took out my '93 windows and replaced them with bullet resistant and they had 2 sets ( one set of mine and another set from another van they did ) they wanted $3200 for one set of 2 windows....they may have a set of seals....this card was in the van package I got from the govt when they turned it over to the auction house...
#574597 - July 18th 2012 4:37 am Re: Remove fixed windows G30 [Re: phils]
phils Offline
Loc: Scotland
Its not the windows im looking for (unless i breake them taking them out..) the weather strip they sit in will be needing replaced so it is really just that part.
Armored windows frscke cheers
what was your van used for laugh
Edited by phils (July 18th 2012 4:42 am)
#574600 - July 18th 2012 5:14 am Re: Remove fixed windows G30 [Re: phils]
They may still have the rubber seals along with the glass....
My '93 G30 454 4x4 EXT thread
http://vannin.com/threads/ubbthreads.php/topics/568276/G30_454_4x4.html#Post568276
My '92 G30 454 EXT thread
http://vannin.com/threads/ubbthreads.php/topics/514618/From_the_begining.html#Post514618
#574753 - July 18th 2012 7:16 pm Re: Remove fixed windows G30 [Re: phils]
phils Offline
Loc: Scotland
boy from www.bauer-millett.com parts department in Manchester is saying he can get me the weather strip non OEM
Part # 15651729 - £119.53 + vat each
i have double checked,this is the correct part number?
yes
#574768 - July 18th 2012 8:55 pm Re: Remove fixed windows G30 [Re: phils]
Just ordered 2 sets....thank you phils for the research...& the good find
#574807 - July 19th 2012 12:26 am Re: Remove fixed windows G30 [Re: phils]
phils Offline
Loc: Scotland
jeeeez that was quick, let us know they look...
4 registered (GoKartVanMan, Lee7673, zank, 1 invisible), 3 Guests and 94 Spiders online.
GoKartVanMan, SuperRob, Rockinrednek, Margaret, ShortChevy
6695 Registered Users
Wizard78 382
frscke1 337
Uncle_Fester 246
keystonekid1978 175
newkirkinc1 153
6695 Members
26242 Topics
