#574786 - July 18th 2012 11:17 pm
How to tighten up loose vent window latches on your Dodge van
For years, I and other Dodge van owners have griped about loose vent window latches. Despite asking on several different web boards populated by very knowledgeable people, I have never found out how to tighten up the latch. In fact, I was often told that tightening the latch was impossible and I should just tape some pennies to the frame and live with it. Tonight, I discovered how to tighten the latches! I am in the process of tinting the windows of my brother's 83 Dodge van and I had to strip the old tint off of the vent windows to put the new tint on. IN the process, I had to disassemble the vent window latches and discovered that it is actually quite easy to tighten up a loose and floppy latch. Follow along as I give a step-by-step pictorial guide to the disassembly and reassembly of a vent latch.  Step one- Put the latch in the "open" position. The latch must be in the "open" position in order to be disassembled and reassembled.  Step two- Find the small roll pin that holds the handle on the latch assembly. Drive the pin out with a hammer and small punch. I found a nail that fit perfectly.  Here is a picture of the roll pin next to a utility knife blade for a size comparison:  Step three- Remove the handle from the assembly:  Step three-and-a-half- The handle contains the plunger, inside of which is a spring with a black rubber tip. The spring amy or may not come out with the handle. It can stay in the handle. If it comes out and get shuffled, the rubber tip goes out, not in.    Step four- Once the spring is out of the way, you can look down the center of the latch assembly and see a Phillips head screw. This is the screw that comes loose and leads to a floppy latch. Tighten the screw, reassemble, and you are done!  Step six- if, like me, you need to disassemble the latch the rest of the way to clean the window or tint it, I have included the following pictures that show, sequentially, how the rest of the latch assembly comes apart. Note the existence and orientation of the various tabs and recesses. It must go back together the right way or the latch will be upside down. Also, the roll pin won't go back in unless the latch is in the "open" position. Wave ring comes off:   Screw unscrews and central shaft comes out:  Grommet comes off:  Outer nut comes off:  Voila! All the pieces of the latch assembly:  I Imagine this will work for most Mopars with this style of latch. Probably 60s through the 90s, but I don't know for sure.
#574788 - July 18th 2012 11:39 pm
Re: How to tighten up loose vent window latches on your Dodge van
[Re: Reed]
Very cool,Since we are talking Dodges Does anybody know how to take out side or rear pop out windows?
#574790 - July 18th 2012 11:52 pm
[Re: Wizard78]
just remove the three screws that hold the latch arm, then pull the window up and slide it out.
#574796 - July 19th 2012 12:00 am
[Re: Reed]
Nice tutorial. I am sure a lot of people are very grateful!!
#574803 - July 19th 2012 12:08 am
[Re: RamVan2500]
just remove the three screws that hold the latch arm, then pull the window up and slide it out. Cool,Thanks I'll check it out. I want to retint them and it's easier and you get a better job if you take them out. Sorry to step on this thread but it's still Dodge windows
#574812 - July 19th 2012 12:59 am
[Re: Reed]
By loose I mean the handle would rotate without latching or unlatching and the handle didn't hold the window shut tight enough to stop leaks and whistling. Tightening up that Phillips head screw will make the window seal tighter because it moves the handle closer to the glass therefore clamping the glass closed more tightly.
I was able to drive the pins that hold the latches to the hooks bolted into the opening windows by carefully tapping them with a hammer hitting a #10 torx head driver. I got the side barn door windows and mid-ship driver's side window out of my brother's van this way to tint the windows.
#574813 - July 19th 2012 1:09 am
[Re: Reed]
nice tutorial Reed, this will be helpful when i go to tint my windows.
#574817 - July 19th 2012 1:28 am
[Re: Reed]
I was able to get all the materials to tint every window on my brother's shorty window van for $146 at Autozone. 35% for the front doors and vent windows, 5% for the midship doors and window, and 2.5% for the rear door and rear windows. BIG difference from before. I think the previous window tint was a worthless 95% tint. Now, you can see out but you CANNOT see in. Just how I like it. Tinting windows is actually very easy. This van is the first vehicle I have tinted the windows on personally, and I doubt I will ever pay the money to have someone else tint my windows again. The most important thing is to get the windows and work area absolutely SPOTLESS. I am probably going to retint most if not all of the windows when I pull them to paint the van in the future, but for now, they are OK. Before:  After:
Edited by Reed (July 19th 2012 1:32 am)
98
25966 Topics
