by FinallyaVanner
the vannin documentary
by FinallyaVanner
by FinallyaVanner
by FinallyaVanner
by FinallyaVanner
03:02 AM
Dash out ?
12:37 AM
switching to power windows?
11:53 PM
11:38 PM
Blown Chevy
by Lordmodelbuilder
11:23 PM
by Hoagie
11:15 PM
Page 1 of 5 1 2 3 4 5 >
#577873 - August 06th 2012 10:57 pm Need advice, blew a rod window size hole in the block.
TriumphZombie Offline
Loc: Van Diego
Here is the story, I am in the San Diego area, I Picked up a 73 dodge van with a 225 /6 engine about a month ago, have been slowly fixing small things/ working out the bugs, recently changed all fluids, went on a 40 mile camping trip, blew a rod and now I have a lifeless van.
Now to the question. I can pull the motor and swap it for another motor, should I try to find a motor from a junkyard? or one pulled from a running vehicle if possible? or buy a rebuilt? or buy a junkyard motor and have it rebuilt before I put it in?
I am not looking to keep the van for very long but want to get her back on the road so I can enjoy her, I already want something a little different for my next one but dont want this one to lose its life. I am looking for the most affordable/ reliable option, I have heard the stories of how bulletproof these motors are, I think I may have gotten a very well abused one.
sorry for the rant, hopefully I can get some great info from all you great folks.
#577876 - August 06th 2012 11:02 pm Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
Sry to hear it....Which ever way you go, the only thing I can say is buy it right or buy it twice....
#577880 - August 07th 2012 12:21 am Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
What is your budget?
Wait for Reed's input if you fancy a slant 6 replacement.
#577890 - August 07th 2012 6:28 am Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
Sorry to hear that
#577901 - August 07th 2012 8:14 am Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
swap in a 318. It will be worth more in resale
#577905 - August 07th 2012 8:47 am Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
If you're going to keep the van, go with a remanufactured engine with a warranty. Any used slant six you go with is going to be at least 25 years old (last year was 1987).
If you stay with a slant six, go with an 81-87 engine since they used hydraulic cam/lifter which means a quieter engine and less maintanence. They bolt-up the same as the older engine AND you don't have to worry about spark plug tube seals on the newer engine.
#577914 - August 07th 2012 10:13 am Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
RamVan2500 Offline
JBWELD
#577976 - August 07th 2012 4:46 pm Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
(1) JBWELD won't fix it
(2) I have heard bad things about the off the shelf reman motors, except for Jasper
(3) Since you are in the San Diego area, you are actually near a large number of slant six aficionados who probably have a few decent runner slants on stands in their garage they would sell, and help you install cheap.
Your fastest solution would be to head on over to www.slantsix.org , join, and post a want ad for a motor.
I agree with Nate, if you are going to go through the trouble to swap the motor out, I say stick in a 81-87 period motor. It is newer and it has hydraulic lifters. Less maintenance. However, if you are just beating the bushes for a cheap get-by motor, don't stress too much about it.
#577978 - August 07th 2012 4:50 pm Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
I went ahead and posted a want ad for you. See HERE We'll see if a slant turns up.
If you are already planning on getting rid of the van, I don't think a switch to a v-8 is worth the effort and resources. Actually, I usually advise against such a swap since doing it right is very time and money consuming, and then you end up with a van that uses more gas.
Edited by Reed (August 07th 2012 4:51 pm)
#578344 - August 09th 2012 6:57 pm Re: Need advice, blew a rod window size hole in the block. [Re: TriumphZombie]
Loc: Van Diego
thanks, I just joined /6.org , and am awaiting approval, I will most likely be keeping the van as its only main issues were within the motor, and whomever put it in last, did kind of a jokey job on it. Thanks for the ad on slant 6, would like to get things goin so I can get some camping done in this thing. I liked the slantys power so I am not sure if i even want to think about a v8. we shall see how this goes.
0 registered (), 0 Guests and 87 Spiders online.
diamond dan
Wizard78 297
Uncle_Fester 293
HighwayStar 252
Lee7673 130
keystonekid1978 123
Reed 107
newkirkinc1 104
6605 Registered Users
6605 Members
25950 Topics
