by CatFish
0 seconds ago
Hello All
5 minutes 35 seconds ago
Today at 01:35 PM
by Deb
Today at 01:33 PM
by relaxedvanner
Today at 11:14 AM
Today at 11:02 AM
Dodge van on trailer!
Today at 09:44 AM
New to forum from WV
Today at 09:41 AM
Today at 08:23 AM
Removing front door hinges 77 Dodge
Today at 08:21 AM
Page 14 of 14 < 1 2 ... 12 13 14
#578433 - August 10th 2012 12:16 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Keep_On_Truckin_WNY Offline
Loc: Buffalo,NY
So this year has been crazy... February started with some 'lower end' noise that i was getting - turned out to actually be my flexplate coming apart, but I didn't know that until it completely separated & wiped out the torque converter & trans in late March...
so the van was down for a week while I got another flexplate (new, from Napa - work discount) and another trans thanks to Stan (SFS60) for finding me a deal on a recently rebuilt Turbo400...!!!
so, then the van was put together and driving again...
in late April, i got laid off at work, which really sucked and hurt, but oh well - that's life i guess...
after a couple of weeks of getting my 'post employment' stuff setup, and adjusting to being home all the time i decided to put all the stuff i had saved for the van on it this summer...
so, prior to April 2012 it looked like this:
i started with a green stripe around the mid section of the van... it's rustoleum Dark Hunter Green, i had 3 cans and used them on EVERYTHING special the van got - they went a long way...!
i put my side slider, and rear pop-outs in - it was a little PITA to get a center piece from a slider with pop-outs, but other than that the conversion was smooth and easy...
when things go bad, you just gotta keep on keepin' on...
progress on my van: http://s193.photobucket.com/albums/z269/95-1Ton/My%20Van%20s/
#578435 - August 10th 2012 12:20 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Looking good
#578437 - August 10th 2012 12:28 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Loc: Buffalo,NY
ok, didn't mean to hit submit yet, but oh well...
after the pop-outs, i fixed stripped the pass. rear quarter above & below the stripe (i already stripped below the stripe) and primed & painted that, then did the rear doors...
the driver's side quarter above the stripe was stripped, primed, and repainted - need to do under the stripe though still...
i got a smoking deal on a front spoiler, so painted that and installed it before the flared boards...
and the center & lower section got custom 'webbing' in silver...
the flared running boards were tricky for me, because i didn't want to make up some brackets to make them functional (honestly, after stripping them and blocking & priming them, i didn't want anyone putting their feet on them...!!!)
so, i decided "What the Hell" and did this:
after about half an hour with a 7" grinding wheel, i cut them down and used some of the original 'glass to make up the bottoms - them put new 'glass & resin over the whole tapered section, some filler, sanding, priming and paint got this:
and added chrome trim rings to my tail lights...
#578438 - August 10th 2012 12:32 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Loc: Buffalo,NY
all the work wasn't just on the outside either...
at various points over the winter it looked like this:
[img][/img]
#578439 - August 10th 2012 12:44 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Loc: Buffalo,NY
until June(ish) it really came together:
the big cabinet, i found on CL for free - and have since sanded & re-stained it (along with the other 2 cabinets and all doors) and added black plexi-glass instead of the ever-breaking real glass...
the ceiling is all paneled now, the 2 side conversion lights are gone & replaced with vinyl-covered paneling (with the lights in them)...
the back doors now have trim around the windows, and the front door panels are different now too...
things are looking up recently - starting a new job soon and the internet's back on LOL...
hope to see many of you at VANTASY 2 next weekend...!!!
#578453 - August 10th 2012 2:24 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Looking good! That center light panel on your headliner is what im trying to find/build for mine.
#578482 - August 10th 2012 6:32 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Loc: Buffalo,NY
that was in my previous GMC Starcraft conversion - it was a '92, and i've seen a lot of them...
i used the whole assembly - the center wood section ties the paneling on the ceiling together, and it has LED's above the 'glass' in the center...
it's not very bright - but it's really cool... i tapped into the dome light wiring so it comes on when the doors open...
and of course, the map lights all work independently...
#580494 - August 23rd 2012 10:53 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
Loc: Buffalo,NY
So after Vantasy I took out my old (almost a year) crappy carpet and replaced it with some great FREE shag from an older lady neighbor...
So, unless I come across something absolutely stupendous, my interior is 'done' for now... Needs some tweaks here and there, but is complete...
#586414 - October 02nd 2012 7:03 pm Re: 84 Chevy '20... [Re: Keep_On_Truckin_WNY]
justaguy Offline
Loc: Trinidad & Tobago
I have a 1981 Chevy G20. What size flexplate and starter did you use? I'm having some trouble with mine. I think i have a V8 305 with a 400transmission.
2 registered (spanishfly, 1 invisible), 2 Guests and 47 Spiders online.
aftoyboy, brianrussell
Wizard78 279
Uncle_Fester 276
NateNCBV 247
frscke1 214
keystonekid1978 140
Reed 134
Superbeast 103
newkirkinc1 99
25910 Topics
