#447284 - February 20th 2011 11:58 amHow to remove a Chevy van engine, made simple
BowTie89
Loc: NW Iowa, SE Wisconsin
I ran into this video on youtube today and it made me happy. I've been asking how to swap motors for sometime and never found out how. The shops would make it sound like an expensive task. BS! If you don't know how to remove your Chevy's Motor, Here it is Thanks to my latest youtube subscription:
1. On the pic where the front section's suspended in the air, where is the top section that raps around the top of the windshield?
2. What is that section called (Section that raps around the windshield)?
3. When above section is installed, does it: A. Have rubber seals that connect it with the roof, held together by the pressure of the windshield & being bolted to the front section, ect.? B. Is it connect by a liquid seal of some type? C. Is it connected by welds of some sort?
Edited by BowTie89 (February 20th 2011 2:07 pm)
"Takes a special kind of person, but a vanner no doubt". 1989 Chevy G20 Sportsvan (Trans-Aire) 5.7TBI Cargo Doors (Vanessa) http://www.cardomain.com/ride/3872412
#447288 - February 20th 2011 12:03 pmRe: How to remove a Chevy van engine, made simple
[Re: BowTie89]
frscke1
When you had it that far why not a frame off restore ?
ONE FOR THE DIRT & ONE FOR THE STREETS http://www.thundersgarage.com/readers.html ADRENALIN BY THE GALLON '93 CHEVY G30 454 4X4 SPORTVAN EXT 146 WB '92 CHEVY G30 454 BEAUVILLE EXT 146 WB
#447326 - February 20th 2011 1:52 pmRe: How to remove a Chevy van engine, made simple
[Re: frscke1]
BowTie89
It's not my van, it's some one's on youtube I ran into this morning. Frame off would be my choice but I'd never known or seen how these motors were removed.
#447327 - February 20th 2011 1:56 pmRe: How to remove a Chevy van engine, made simple
[Re: wookee]
BowTie89
Is this not right or something? I'm lost..Don't tell me this is all photoshop?
#447371 - February 20th 2011 4:09 pmRe: How to remove a Chevy van engine, made simple
[Re: BowTie89]
Bryce
Loc: New Hampshire
Doesn't look like photoshop, but I think the person who made that video is having a little fun with people. You can take apart a chevy van to get the motor out like that, but it won't exactly go back together by "reversing the steps". My guess is this van was being scrapped but they were saving the motor. Do not cut the front of your van off.
Also technically "frame off" restoration isn't possible on a unibody van, but that's just splitting hairs. I know what you are getting at and you could come pretty close by removing the front subframe and all suspension and driveline. You could then access all tricky to get at places, but really those are not often a problem on these vans.
Common rust spots are all the lower outside body panels, which replacement panel are mostly available for. Also the front subframes themselves some times rust, those are a bigger problem.
#447379 - February 20th 2011 6:00 pmRe: How to remove a Chevy van engine, made simple
[Re: BowTie89]
Doc 2% of Canada, EH!!!!
Yep, don't believe everything you see on the net !
Everyone knows you take the fiberglass roof off and hoist it through there !
I don't need to be honoured by Vanning, I am honoured to be Vanning ! Supporting Vanning, by going Vanning! I hate it, when real life interferes with Vanning ! Ford Lover now in a Ford Body ! 97Errorstar,05 Freestar Van Clan Plus One, Vanning since 1977 ! Ontario Federation Of Truckers (Vanner's) Ottawa Valley Vans Founder,Mixed Bag Truckers Co-Founder,Twisted Truckers,S Joisey, If you don't like my sense of humour,don't read my posts ! Never assemble an engine after BUCKET !!
#447381 - February 20th 2011 6:01 pmRe: How to remove a Chevy van engine, made simple
[Re: BowTie89]
frscke1
I thought all that came off was the grill , rad, some wire harness and hoses un bolt and cherry pick it out....whats with takin the cab and 1/2 the ft just to get to the block
#447423 - February 20th 2011 8:55 pmRe: How to remove a Chevy van engine, made simple
[Re: frscke1]
Bryce
Loc: New Hampshire
Originally Posted By: frscke1
I thought all that came off was the grill , rad, some wire harness and hoses un-bolt and cherry pick it out....what's with taking the cab and 1/2 the ft just to get to the block
If you don't care about putting it back together then yeah, sawz-all the whole front off. But for a motor swap on a van you want to keep, yeah you are absoulutely right, out through the front.
Hardest part is that you don't have much space to lift the engine before pulling it out. I have heard of people strapping the boom directly to the top of the engine, not hanging from the chain, because even with just a few links, the boom hits the bottom of the engine shroud/firewall before you even get it up off the motor-mounts.
