Lookin' out my Side Doors
Auto Electric Plug
by mud
Poison Ivy Memorial Day Campout! May 25-27, 2013. Zillah, WA.
by Charley Olenak
Seller beware and LIVE
Page 2 of 3 < 1 2 3 >
#45380 - March 16th 2006 10:36 am Re: First time Engine Removal
I took my 4.3 out of my 93 the front
<img src="http://img.photobucket.com/albums/v304/wookee10358/gmc%20engine%20pull/outthefront.jpg" alt=" - " />
You can drop the crossmember like cheygod did and drop it out the bottom but then you need to come up with a way to lift the whole body up to roll the engne out.Or cut the fron valance.
The biggest problen I found was finding a replacement 4.3.
GM stopped prodicing 4.3 crate engines and only offer a factory remaned 4.3
I had a local machine shop rebuild mine for $1,300.00
<img src="http://img.photobucket.com/albums/v304/wookee10358/gmc%20engine%20pull/fresh4.jpg" alt=" - " />
I have yanked engines out of a couple of my earlier Chevy vans. This one was a challenge because of all the extra junk they have added to these later model engines.Not really a recomended job for an inexperianced mechanic.....
Your knock sounds like a risk pin.
Electronic gauges being inaccurate is a myth
Even with the high mile my 4.3 would run 60lbs when cold.I have ran electronic gauges with GOOD results.All of my late modle GM's have factory electronic gauges in them.
Mine always ran quiet.I was able to put 240,000 miles on it before I yanked it......Wookee
<small>[ March 16, 2006, 10:54 AM: Message edited by: wookee ]</small>
#45381 - March 16th 2006 10:58 am Re: First time Engine Removal
pbrady73 Offline
Dude i cant thank you and everyone in this forum for the pictures and help. I totaly understand how it comes out of there now. The wrist pin makes sense. Once the aluminum piston expands, the clearance becomes greater causing the noise. DOH! I think it's time to get the garage organized! I got's me a motor to pull <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
#45382 - March 16th 2006 11:34 am Re: First time Engine Removal
chevygod Offline
Loc: Corona, California
Yes, on my van I cut the fron header behind the bumper. I will fab it to be a bolt in part later. This meant I didn't need to get the van quite so high up, just enuff to clear the tires.
If you can get the body high enuff to drop the motor/trans without cutting the header bar, this is the way the van is built, with everything loaded from underneath. Otherwise, the mototr comes thru the front with little or no trouble. Just take your time and work slow and it'll happen.
Best regards,
Tom
#45383 - March 24th 2006 10:12 am Re: First time Engine Removal
pbrady73 Offline
The adventure thus far:
Ok i have the motor stripped down ready to pull out. If everything goes right i will have it out this weekend. You know this isnt as bad as i thought!
Anyway the only bit of bad news is that this v-6 is freaking EXPENSIVE!!!! The roller v-6 with the balance shaft is not cheap and it's hard to score parts if you want to tweak it a bit.
That being said, i have decided to upgrade it to a V-8 because it's cheaper and i really need the horsepower. I'm afraid the V-6 would not be happy climbing the mountians around Ouray, Co, plus hauling camping gear and dirt bikes.
My only concern is the ECM. My computer in the van is also used in V-8 equiped trucks and vans. To do the conversion, do i just need a chip that is for that V-8/ transmission combo?
I'll take some pictures of it this weekend and post them. Thanks everybody! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
#45384 - March 24th 2006 2:39 pm Re: First time Engine Removal
chevygod Offline
I believe most all of the wiring, brackets, and accessory components will work from 4.3-6 to V8. You will need an intake, distributor and related parts for the plug wires, exhaust manis and maybe Y-pipe, possibly motor mounts and mount stands on the frame, fan shroud and maybe fan & clutch.
Check with someone in the know about the TBI units, as it may be the correct unit, but may need bigger injectors. I know a 4.3 Astro TBI unit has a different throttle cable actuation method than my 5.7 TBI unit I have from an 87 G-Van (I think the Astro 4.3 cable pulls from the front while the 5.7 cable loops around the motor and pulls from the rear). Also, you will need extra hardware (nuts and bolts) as there are 2 extra cylinders and everthing that bolts to them.
I believe the wiring will fit as far as length, but you may end up with AC , heater, and radiator hoses being a little long, as the accessories have moved forward.
If you know someone with a V8 version of your van, do an A-B comparison of the 2. Out her in SoCal, V-8 TBI vans are becoming common; I don't know the parts yard resources you have avaiable to you. In the end, after pricing and sourcing parts, you may find the 4.3 to still be the way to go after all.
Best regards,
Tom
#45385 - March 24th 2006 3:10 pm Re: First time Engine Removal
pbrady73 Offline
I live in the Dallas-Ft. Worth Metroplex and belive me the yards down here are FULL of vans! I have my eye on a 1994 G20 chevy with a v-8 still in it. all of the electronics are gone, but all of the hard parts remain (motor, manifolds, mounts, intake, pulleys, ect) i have seen some other vans with the injectors and tbi setup. If any of you guys ever make it down to the dfw area, the wrecking yards are worth a visit!!!! Ive seen some early stuff show up here and there.
The front springs will need to be updated as well right?
#45386 - March 24th 2006 4:13 pm Re: First time Engine Removal
chevygod Offline
Damn, I forgot the springs. You may need to change them unlees you're interested in having the nose dropping a little. I don't know the difference in weight btw a 4.3 and a SBC, but I imagine it cannot be much. Once you have the swap completed, see how she sits and corners. It you like it leave it alone.
Find a rebuilder that ships motors, they should be able to give you a weight for each motor,
Different subject, but if you see a Late G (91-95 I think) with factory powere mirrors, give me a shout. That is the only setup I need for my van before I button everything up.
Best regards,
Tom
#45387 - March 26th 2006 12:11 am Re: First time Engine Removal
When I was thinking about swapping my v/6 to an 8 I found out that the puter and the chip is the same as the v/8.
I never hauled any thing but kids and ass in my van.If you are planning to do allot of traveling in mountian ares, and you guys have real mountians out west.The V/8 swap will be worth the extra money spent on the swap............Wookee
#45388 - March 27th 2006 9:17 am Re: First time Engine Removal
pbrady73 Offline
It's out! I am honestly surprised how easy it was to do. I made a wrecking yard run this weekend and scored a TBI 350 complete with all sensors, throttle body, and distributor for 200 bucks. The adventure continues
#45389 - March 27th 2006 11:29 pm Re: First time Engine Removal
pbrady73 Offline
here is some great info i spotted on the net.
This guy is a TBI guru!!! www.tbichips.com
Hope this helps anyone wanting to take on this project!
Q1. Can I replace my 4.3 or 305 with a 350 V8?
A1. This has to be the most common of them all. This is an easy swap as long as proper preparation and planning is used. All the accessories/brackets and wiring can be used on the 350. 4.3L V6 guys will have to add a distributor and exhaust manifolds (headers) to the list but here are the basics to keep TBI happy.
You need a TBI friendly 350. Look at my recommended modifications page to see about cams and such for TBI friendliness.
Computer wise. The S10 guys should change the computer to a 1227747, 1228747 or 16146299 computer which all came with the V8 engines. It should plug right into the S10 harness.
Then the hardware that you need to change is the injectors GM Part number 17112493 5.7L TBI injector, GM Part number 17111784 7.4L TBI injector (1988,1989,1990). Injector choice will depend on hp you build that 350 for. Next, you will need to change the knock sensor GM part number 10456288.
Finally you should change the electronic spark control module GM part number 16128261 since they are calibrated to the displacement of the engine and using one from a smaller engine could cost you some horsepower since it will be more sensitive.
Lastly the chip, I will do what I can to make you a chip that will run your engine and the success of you swap will depend on how well you followed the first 3 items.
6 registered (keystonekid1978, al55, phils, Lee7673, Sean_and_Peggy, cammyjee), 5 Guests and 107 Spiders online.
Uncle_Fester 303
Wizard78 297
HighwayStar 253
NateNCBV 234
al55 116
newkirkinc1 110
6609 Registered Users
6610 Members
25969 Topics
