#468996 - May 20th 2011 10:04 am
Re: Another HIGH PERFORMANCE CHEVY VAN!
[Re: Superbeast]
Loc: north side of the Netherlands
Can you tell me some more about the flipfront? We are working on a Van that's also getting a flipfront. Is the cilinder air-commanded? Can you make some pics of the construction you've made? Very very nice Van you're building  Thanks, Ronnie
VANS; don't just ride it ** CUSTOMIZE IT **
#469056 - May 20th 2011 6:20 pm
[Re: moparronnie]
Loc: MARYLAND
Can you tell me some more about the flipfront? We are working on a Van that's also getting a flipfront. Is the cilinder air-commanded? Can you make some pics of the construction you've made? Very very nice Van you're building  Thanks, Ronnie give me a call and I will tell u how the tiltfrontend was built,and u can look throw my thread at the pics.
 "IT IS NOT A REAL VAN,UNLESS IT IS A PROSTREET VAN" !!!!!!!!!!!!!!!!!!
#469342 - May 22nd 2011 9:30 pm
[Re: moparronnie]
Loc: MARYLAND
Can you tell me some more about the flipfront? We are working on a Van that's also getting a flipfront. Is the cilinder air-commanded? Can you make some pics of the construction you've made? Very very nice Van you're building  Thanks, Ronnie the cilinder is electric that open it up.go throw the pages n u will see pics of the tiltfrontend.it is built with a 2 part hange at the bottom on each side so it can fully open up all the way out.most tiltfrontends open up a 1/4 of the way out ,because they r hanges up high.the tiltfrontend is not a easy thing to make work.my tiltfrontend can be removed on n off at anytime. let me no if u have any quiestion!!
#469376 - May 23rd 2011 12:39 am
[Re: MACHINIST]
Loc: Minnesota
moparronnie, you have to go back to pages 8-11 to see pics of the tilt front end, the body work on Brian's van here is great and you have to check out all the pics from page 1 as he has made changes throughout the build.
Star Dreamer 78 Full Custom Chevy Ramblin Vans - HVC Honorary Mild to Wild Van Member - Houston, TX. She's not a trailer queen, she is just on vacation! She even pulls trailers!
#469653 - May 24th 2011 2:06 am
[Re: Star Dreamer]
I've read the whole tread, but not sentense by sentense. I think I'll do that  I've seen some specs about the flipfront but not everything I'll have to know, but what I sead: I will read every sentense and when I have questions after that I will be here again. Thanks, Ronnie
#469676 - May 24th 2011 8:57 am
[Re: MACHINIST]
There is no word for word description of this set up. looking at the picture it does not really look like a standard hinge. Here is a picture of the hinge.before the body work was finished around it  The bolt at the bottom is the pivot point. The custom made bracket is welded to the end of the frame horn....... Remove the bolts and a couple other mounting points and the complete front end can be "walked off" .........Wookee
#469905 - May 25th 2011 7:09 am
[Re: wookee]
I've seen al the pics again and know how I want to do it. Everything is there in the pictures if I look closer. Which manufacturer made the cilinder for the flipfront? Do you have some specs of yours? Around the corner is a gay who has a hydraulics store. Maybe I'll let it run on hydraulics.
Thanks, Ronnie
5
60
6608 Members
