#488314 - August 14th 2011 6:24 pm
Any woodworkers ???
Loc: NW Pa
I stained the workbench and a few other pieces in my van,a week ago, and it STINKS how long does it take to remedy that ? I used Minwax wood stain.
I DID NOT Escape, I'm on a Weekend Pass Lifelong Disease, WhiteLine Fever 97 DODGE shorty, The ROCK & ROLL Train New 4 Seasons Criuser, 74 B100, The Night Train Member of the Toopa Sinner Tribe
#493827 - September 04th 2011 2:01 am
Re: Any woodworkers ???
[Re: PYSCHOWard]
Minwax.
This stuff must be wiped off before it completely dries, but then you might lose some color you were trying to keep. You can push the color deeper in some end grain, and just as easily pull it out of the flatter grained areas "Oh! that's What she said!" Sorry. Saturday night and all that.
Wiping it off and blending it can to keep an even color can be a frustrating task, depending on the wood, and how it was prepped before you slapped a stain soaked rag on it and spread it around.
I have yet to use a wood conditioner, not out of malice, or doubt, just inexperience in the using the product, perhaps inpatience too.
It will stink for weeks if you did not wipe it down.
If you did not wipe it down within a few hours, depending on temp and humidity it can be an overwhelming PITA. to wipe down later.
I have wiped on another layer of stain on top of the gummy stuff, then that is easy to wipe off, and blend
I have also used a darker stain than intended let it sit overnight, then used mineral spirits on a rag to wipe it off and blend the color evenly, and polyurethaned that 2 hours later with excellent results.
Minwax might be widespread and popular, but on the fine woodworking sites I used to frequent, it was laughed at,reviled even.
#495337 - September 09th 2011 9:17 am
[Re: PYSCHOWard]
I hope I'm not hijacking this thread before it was finished, but had a woodworking question of my own. In 2005, I pulled the plastic grille on my van, replacing it with an early alumunum unit. Since my van had "D O D G E" lettering on the hood, I took the "DODGE" insert out of the early grille and replaced it with "JUNKYARD JITTERS" lettering.  I cut the letters from a piece of cabinet grade birch plywood (dont ask me why I didn't use some of the extra red oak flooring I also had). After staining, I sealed them with 5 coats of water-based urethane (2 coats on same day, 1 day drying time, 2 coats, same day, etc.) Now the letters are faded, falling apart (see pic below) and ready to be replaced. This time, I took the lazy way out and bought some pre-cut solid wood letters (which hopefully will last longer). Have any tips on what to seal them with? Do I Just need to re-seal every other year? Is 5 coats (applied w/brush) too many?
1 registered (i dig boogers),
31
6702 Members
26260 Topics
