#532182 - January 23rd 2012 1:03 am
Re: Steam out the tailpipe
[Re: Altosax]
Was the cross hatching still visible on the cylinder bores? I don't know that I would have been comfortable reusing that block unless it was re machined. Whatever it was that was bouncing around in the cylinders and pitted the piston heads also had to do a number on the cylinder walls. Wouldn't think the rings would seal very well. Here is what a roller cam'd LA 318 looks like.  The re machined heads, they were magnafluxed to check for cracks? Here is a magnafluxed crack in the head when I had my engine rebuilt:
#532183 - January 23rd 2012 1:04 am
[Re: Grogan14]
Loc: So Calif
Do they take enough off of those heads in truing them that the intake manifold needs to be milled to match? Good Q Grogan14, I asked the shop and they said they took only very minimal amount, not shaved but just enough to clean surface. I aked if I would need to machine intake mating surface and was told it would match fine. Vacuum is good - like 20 - but I guess that wouldn't prove the seal was great beyond the vac measure itself. I forget the Edel torque spec but that's what I used. As I recall it is quite a bit less than Dodge FSM. I have no steam from pass side though with same torque on bolts.
#532185 - January 23rd 2012 1:14 am
[Re: Altosax]
Loc: Live Free Or Die
I forget the Edel torque spec but that's what I used. As I recall it is quite a bit less than Dodge FSM. I reckon that's due to it being aluminum. Did you figure out what that was, bouncing around in that cylinder?
#532188 - January 23rd 2012 1:30 am
[Re: Altosax]
I theorize these Mopars are extremely forgiving. Runs cool, not a high compression, etc. Maybe it will blow up - I ain't sure.
I'll be interested to see if there is much oil consumption if you can get it to stop steaming. Is there any coolant in the oil?
#532189 - January 23rd 2012 1:40 am
[Re: Altosax]
Edelbrock says to torque their intake manifolds to 25 ft pounds. Get the installation instructions HERE. If it is getting good vacuum and nothing is leaking from the exhaust studs, you may want to just run it for a few days and watch your coolant level. About 10 years ago I had the 351 that is now in my 89 Ford rebuilt by a very reputable shop in town. The engine builder said that the motor would leak a little at first until it was broken in. Sure enough, I had a little bit of coolant seeping past the intake and head gaskets. However, it settled down after a few days of driving. There is also the chance that what you are seeing is just condensation. Try topping off the radiator and taking the van for a good long drive. If the van doesn't overheat and you don;t have white smoke when you get done, then you are fine.
#532491 - January 24th 2012 2:11 am
[Re: wrcsixeight]
Loc: So Calif
I'll be interested to see if there is much oil consumption if you can get it to stop steaming. Is there any coolant in the oil? Nope, no coolant in the oil, tho it has not been run very long yet. Engine has good compression, too. I saw your interesting thread in "Bob Is The Oil Guy" about your rebuild some time ago.
96
6608 Members
25962 Topics
