by on the road
6 minutes 21 seconds ago
11 minutes 52 seconds ago
14 minutes 56 seconds ago
How d I remove a front axle on an 89 E-150?
23 minutes 13 seconds ago
The Factory Options Thread
32 minutes 34 seconds ago
Latest tuner trend. . . .
47 minutes 47 seconds ago
the green van
by gwkh
Today at 08:14 PM
Lost in the Wild Wild West May 23 to 27, NY.
by Richbeer
Today at 08:12 PM
by heavy389
Today at 08:04 PM
#80471 - January 15th 2006 8:40 pm thinking about buying an awd
gypsy Offline
Loc: Western NY
I've been out looking at vans and I found a 2003 Astro AWD. Anything I should be looking for (problem areas,etc)? Any help or comments appreciated.
#80472 - March 08th 2006 2:52 pm Re: thinking about buying an awd
phrog Offline
Hoavc Chairman 2006-2009
Loc: Kansas City, Mo
Problem in later AWDs 95 and newer is electronic motor that triggers awd action is weak link. Cost $150 to replace
#80473 - April 16th 2006 10:47 pm Re: thinking about buying an awd
VanVida_Israel Offline
Loc: KS
not bad cost repair...we have a 2000 awd astro & 92 gmc safari awd...really like them both...next to purchase is a 2005 awd astro,not sure when
#331775 - October 06th 2009 7:54 pm Re: thinking about buying an awd [Re: VanVida_Israel]
Bullet Offline
Loc: Bristol, TN
We've had our '99 AWD for about 5 years now, wouldn't want to be without it. It did seem sluggish compared to the 2wd versions I assume because of the extra rotating mass, recently the transmission took a powder thanks to pulling our camper up a long mountain grade. I put another in with this kit https://www.700r4l60e.com/store/product.php?productid=366&cat=64&page=1 the difference is almost overwhelming. It does shift hard, probably too hard on 1-2 for most people but since this van sees a good bit of towing, I can live with it. The performance is a HUGE difference and picked up 2-3 mpg in the process. It is getting tons more power to the ground and pulls hard and steady, the shift points are perfect for everyday driving as well. I would highly recommend a tranny cooler after you get the van, the transmissions work hard in the little Astros. I put a 30k gvw cooler in it and it runs 70-80 mph pulling 2500 lbs of camper and gear and the tranny runs around 200 degrees all the time. It's a great family workhorse and still strong after 160k miles.
'85 GMC Shorty
'99 AWD Astro
'55 Chevy 150 ex-racer
#543118 - February 27th 2012 6:44 am Re: thinking about buying an awd [Re: gypsy]
astro_ruhroh Offline
Loc: New Hampshire
the only issues i have had with my 2000 astro is the heater vent selector diddnt work cause of a couple of bad vacuum lines (one across the engine to the pcv valve connection, and the other to the vacuum resivoir) and the transfer case binding cause of old fluid there is a tsb on the fluid use in your 96-05's where you use GM's AUTO-TRAK II fluid, other then those i have had no trouble
#543123 - February 27th 2012 7:51 am Re: thinking about buying an awd [Re: astro_ruhroh]
MrHoney Offline
Loc: NY
I say go for it if its your everyday ride its best to have a 4X4 in WNY.
shift
#543170 - February 27th 2012 12:04 pm Re: thinking about buying an awd [Re: MrHoney]
AWD astro's make excellent daily drivers ,,, smile
#543513 - February 28th 2012 3:54 am Re: thinking about buying an awd [Re: gypsy]
I almost wish my Astro was a AWD, specially when the snow/ice flies around here. . . . . Would make me feel a bit safer, you know?
Just to tease you, check THIS GUY OUT
#543536 - February 28th 2012 7:51 am Re: thinking about buying an awd [Re: gypsy]
Phrog had one and the engine went south on him.....scrapped it as that particular engine was problematic and the hard to find in the wreckers
97Errorstar,05 Freestar
Ottawa Valley Vans
Founder,Mixed Bag Truckers
#543895 - February 29th 2012 9:07 am Re: thinking about buying an awd [Re: gypsy]
Bullet Offline
Loc: Bristol, TN
I saw one over on one of the Astro Safari channels that lifted his and put a 502 Ramjet in it with a 4L80E. Just goes to show you, if you stand back and throw enough $100 bills at it, you can do anything. With the lift which lowered the front subframe, he put the stock doghouse right back on it. Very cool van.
I too had vent issues, the heat made the hard plastic vacuum tubing pop like a toothpick.
'85 GMC Shorty
'99 AWD Astro
2 registered (Greywolf, on the road), 7 Guests and 71 Spiders online.
diamond dan
Wizard78 304
Uncle_Fester 301
NateNCBV 227
frscke1 210
keystonekid1978 126
al55 113
Reed 107
newkirkinc1 104
6607 Registered Users
6607 Members
25960 Topics
