1993 GMC Vandura 3500 w/ 454 7.4L stalling at red lights
by 77CoachmenG20
by MACE
by Charley Olenak
Dash out ?
by Stingxray
by HomeBrew
01:09 PM
12:29 PM
12:26 PM
12:25 PM
12:24 PM
Latest tuner trend. . . .
11:22 AM
#558356 - April 25th 2012 1:40 pm Need a source for small cut off wheels
Lee7673 Online   content
I am looking for small cut off wheels (like 1.5") that will fit an air angle grinder. I found some but they are made for a small hand tool and they have like an 1/8" shaft and the air grinder will only go down to a 1/4" shaft. I drilled out the center of the cut off wheel to mount on the larger shaft but it disintegrated after about a minute (guess it was designed for less rpm's).
Thanks
#558359 - April 25th 2012 1:52 pm Re: Need a source for small cut off wheels [Re: Lee7673]
For the big ones ...
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1%2F4%22+hole&op=search&Ntt=cut+off+wheels|1%2F4%22+hole|1%2F4%22+hole&sst=subset&N=
for the small ones....
http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=456
#558362 - April 25th 2012 2:02 pm Re: Need a source for small cut off wheels [Re: Lee7673]
Another option is to put a sleeve on the 1/8 shank to fit your 1/4 collet...
#558364 - April 25th 2012 2:04 pm Re: Need a source for small cut off wheels [Re: frscke1]
That's what I did but the wheel just broke apart....don't think it was meant for high rpms???
#558365 - April 25th 2012 2:10 pm Re: Need a source for small cut off wheels [Re: Lee7673]
Dremel has some wheels about that big
#558395 - April 25th 2012 4:29 pm Re: Need a source for small cut off wheels [Re: Lee7673]
Dremel does make two styles of cut off wheels a light one and a heavy duty one.
The heavier one if have used with good results.
I still have the same Dremel tool I bought for doing car models back in the day.....LOL
A cut off wheel will disintegrate if used at too high RPMS
....Wookee
1 registered (Lee7673), 1 Guest and 81 Spiders online.
NansZ
Wizard78 291
Uncle_Fester 287
HighwayStar 248
frscke1 220
keystonekid1978 126
newkirkinc1 107
Reed 105
76GreenMachine, Edoz, FordVanMan66, SpringWater, Dale38
6603 Registered Users
6603 Members
25939 Topics
