#559979 - May 03rd 2012 9:36 am
Re: Winter project, tubbing my 98 Astro
[Re: GhostRyder]
Loc: Michigan
radicalran: I didnt know there was 2 BB pro street Astros by Toledo. I wouldnt mind seeing them. Not sure about the cargo net, but it does finish off the sorta stock looking interior.  worked on the exhaust heat shields, it is taped on, still needs a little filing before final mounting.
1998 LS1 powered pro street Chevy Astro PRO STREET 4 LIFE
#559993 - May 03rd 2012 12:18 pm
[Re: badassastro]
Shoot! 6 inches, that 4x4 territory  It does look badass though!
#560182 - May 04th 2012 12:50 pm
[Re: badassastro]
Loc: Michigan
Bigair: Thank you. Keep it some what stock looking is the goal, any body can cut up a vehicle, it putting it back together that is the hard part. It has caused a lot of extra work, had to make a few trips to PnP for interior pieces. Fitting pieces around the roll bar was a biotch, but it was worth it.
drag: Thank you. My 85 pro street Astro (RIP), the header flanges and deep tranny pan would hit some times. This Astros deep tranny pan is not as thick and front bumper hangs down farther, just not worth damaging stuff. If it wasnt street driven & Michigan didnt have some of the worst roads in the country, would be different.
#560377 - May 06th 2012 9:25 am
[Re: badassastro]
Loc: Michigan
Custom fuel tank done  side view, bottom is angled for a built in sump  installed  fill tube and vent, will be cover with trim and a carpet tunnel  fuel filler, later on will be replace with a flush pop out door, this will do for now
#560470 - May 06th 2012 10:33 pm
[Re: badassastro]
Loc: Michigan
Finished gas filler, it is a boat filler, wouldnt rust.  Put some gas in it, started rite up after building fuel pressure. Just need to do exhaust and a few little things, will be cruisin by the weekend.
#560476 - May 06th 2012 11:56 pm
[Re: badassastro]
Loc: Shanghai China
#560504 - May 07th 2012 6:30 am
[Re: badassastro]
Loc: Calgary Alberta. Canada
Wow, that looks great. Must have been nice to hear it come to life.
Shanning P. Alberta, Canada  1991 Dodge Ram 250 Mark 3 Member of Vandits VC. Calgary
#560845 - May 08th 2012 4:27 pm
[Re: badassastro]
Loc: Michigan
Yep, awesome to hear it run. Took it to car wash for a badly needed bath. Took a few pictures, soory it was hazy and gloomy this morning. New front end, went from an Astro sealed beam to a composite Safari, with a billet grille & Chevy bowtie   I think I will be raising rear end up 1 hole, about 2 inches, could use some rake.
#560868 - May 08th 2012 5:26 pm
[Re: badassastro]
Loc: Shanghai China
Looks great!!! I love the grill and obviously the van sits right. I am impressed. Great job!
7
60
25910 Topics
