#389680 - June 04th 2010 10:39 pm
Re: Did some "glassin" Today
[Re: Superbeast]
Looks good so far. You gonna mold it all in? Going to try Ken  Probly wont behind bumper,but the rest will B, Mite B some kinda body line but.....we will C,fiberglass is amazing!
#391073 - June 13th 2010 12:05 pm
[Re: heavy389]
Did pass/side today  Ground it up   Laid some mat    Took care of the dimpples/spot welds,that R left from tack welding floor to outer skin while here,did otherside ,they were worse!!!  took some strands of glass mixed witt resin and put in after grinding out,and treatin rust!  Will hit them witt sander when doing outter sandin!! Time for a cold one and pool right now!!!! More 2 come!!
#391461 - June 14th 2010 8:32 pm
[Re: Superbeast]
Looks good so far. Will the mat be enough to hold the dam on or is there other mounting besides the 2 screws? That is just 2 of the 10 screws  When U say Dam...meening Roll Pan? If so she's screwed,glued,and a few layers of matting,I dont think its going anywere,I had it on before just screwed across back and 2 you see in pic,and it was glassed on sides & were it touched flairs Ken,It worked fine then,I had to use stright cut off tool to cut it off when I took it off to put tralier hitch on.So all that attaching and the matting I dont see any wind resistinace problem
#404199 - August 10th 2010 4:42 pm
[Re: Superbeast]
Had a little spat witt boss today an told em C ya tomarrow! So had chance to do some more on van,have been neglecting it 4 a few months,have a boat in a slip on bay and have been fishing every sat & sun 4 past couple months!!! So I saw today as a chance !! Got a little bondo on  I use magic marker to mark low spots,its like ya dont wana waste no more bondo than ya need,takes lotsa layers of it to get all the low spots so this helps just puttin it were ya need it,most gets grated off and ends up on ground anyways! lol  After a few puddys!   After around 3 hours I called it quits and jumped in pool!!   The black is a rust encapsulator stuff I got from Eastwood,when ever I finish I spray it on all bare metal,then some I would spray primer right over it while it is still wet!! fills almost like a Nitro Stain puddy!! The primer will show ya were ya need more puddy too!! I need to do a little more work on lower flair area ya can C !! Well more next time!
59
