by NateNCBV
Rear breaks on a 2001 E350
by Garfield
New Group on Facebook
by erichitscar
11:44 AM
Midwest Vans Ltd's 39th Midwest International Truck-In May 24-27, 2013
by Suzie-BGfNY-IN
11:01 AM
Hello from the UK
by pearly
11:00 AM
Taking power windows from a Clubwagon to a Cargo Van....?
10:14 AM
Hi from Ontario, Ca
10:08 AM
by Suzie-BGfNY-IN
09:57 AM
86 G20 1st Van Build!!
by Bikertrash00
08:02 AM
#570722 - June 25th 2012 1:13 pm Leaky Thermostat Housing
strangeblue Offline
Loc: Chattanooga, tn
I changed out my water pump this weekend...
almost did my timing chain... but chickened out. (afraid I might screw something up.)
But anyways. I bought a new thermostat and rubber seal.
but everytime I start the car. It Leaks...
In between the seal and out of the screws...
I have tightened the screws as good as I can.
Do I need to use some liquid seal of some sort?
What to do??
Click for large view - Uploaded with Skitch
"Trade what you got - To get what you want"
1995 Chevy G20 Custom Choo Choo
Facebook Fan Page - click here to visit us
#571107 - June 26th 2012 9:59 pm Re: Leaky Thermostat Housing [Re: strangeblue]
Uncle_Fester Online   content
First off, good job so far! I would clean that black stuff off the mating surface with a wire toothbrush, then a THIN coat of blue RTV around the mating surface of the T-Stat housing ( the dome part you took off), put it all together and DO NOT OVER TIGHTEN! I install mine with a 1/4 drive ratchet so as not to over tighten. Give it about ten min or so to "set up" before you start the motor.
This is how I do my t-stat swaps twice a year. I run a 160* in the summer, and a 195* in the winter. SEAMS to keep it cooler in the summer and better heat in the winter. . .
#571152 - June 27th 2012 7:26 am Re: Leaky Thermostat Housing [Re: strangeblue]
Bullet Offline
Loc: Bristol, TN
Is it just seeping a tiny bit or is it more than that? Clean the recess in the intake, get a good piece of 220 grit wet/dry sandpaper and place it on a flat surface, attach it some way, 2" tape all the way around, then put your thermostat housing on it and work it in a figure 8. Do this about 20 times and check the bottom, if it's warped you will notice some areas not touched by the sanding. Keep doing this until its nice and flat, you may have to use a couple pieces of sandpaper. If it's warped bad, you may be time and money ahead to replace it. It should seal with the rubber O-ring without using any RTV, but a thin, thin coat of sealer wont hurt anything. Don't over torque the bolts as this can cause problems too.
'85 GMC Shorty
'99 AWD Astro
'55 Chevy 150 ex-racer
#571196 - June 27th 2012 12:17 pm Re: Leaky Thermostat Housing [Re: strangeblue]
NateNCBV Online   content
If the bolts thread into a water jacket, you will need some thread sealer on them.
#571215 - June 27th 2012 1:35 pm Re: Leaky Thermostat Housing [Re: strangeblue]
vanatic05 Offline
Vanaholic
Loc: Auburn IL
Also it looks like you have another gasket in the block still remove the old gasket...
Darrin Bentley
Director: Vanatics Van Club
92 GMC 3500 454/4bbl
roiboi65@yahoo.com
www.vanatics.com
#571306 - June 27th 2012 9:31 pm Re: Leaky Thermostat Housing [Re: strangeblue]
If you have a chrome housing they all leak until you take them to a belt sander and make them flat on the bottom... Just a thought , it is what I had to do.
5 registered (Dodgecamo, Uncle_Fester, Bikertrash00, NateNCBV, SaabGuy), 3 Guests and 16 Spiders online.
Uncle_Fester 317
Wizard78 311
NateNCBV 228
frscke1 207
Lee7673 137
keystonekid1978 126
al55 120
newkirkinc1 115
Ripper 115
erichitscar, elmonoverde, jimmyn141, TheWhiteKnight83, GearheadFlicks
6618 Registered Users
6618 Members
25972 Topics
