Rear breaks on a 2001 E350
by Superbeast
Hello from the UK
by NateNCBV
by Superbeast
by Superbeast
by Superbeast
by wrcsixeight
Dissatisfied Customer
by Suzie-BGfNY-IN
Page 2 of 3 < 1 2 3 >
#568975 - June 16th 2012 5:57 pm Re: Inexpensive Solar. 100 watts 140$ [Re: frscke1]
Does the intended Van have a third brake light?
I've got a bunch of these going through my fiberglass roof under the framed panel.
Water tight and provide strain relief.
In 2007, my 130 watt panel was 720$$
Check that original link as there have been 140 watt panels for 189$$. It is pretty hard to have too much solar.
Note that 24 volt or higher nominally rated panels require an MPPT charge controller. MPPT controllers basically are dc to dc converters and keep battery voltage from limiting the total panel output. In cold sunny conditions with depleted batteries the output can be 30% more then regular PWM controllers. Due to the cost of the MPPT controllers, it is basically cheaper to get another panel, if you have the room.
My 200 watts are making 13.4 amps as I type, powering my TV, this Laptop and compressor fridge and 5 muffin fans with almost 4 amps still going into my batteries.
#569040 - June 17th 2012 1:47 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
In the long run Im going to put a low hi top on it and have the panels set in the roof...so any holes will be sealed when they put the hi top on...but in the mean time a portable will do..
#573236 - July 09th 2012 1:07 pm Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
WRC68 I got another question....
100 Watt: PV-SC100J12
On solarblvd.com they say it is 43" long and on solarenergy.com they say the same unit size is 57" long...
Do you have one & which is it ?
thanks in advance....
#573798 - July 12th 2012 11:50 pm Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
A flexible solar panel...Is this a good thing ? Im not a electronics guy but I like the low profile of it....
http://www.amazon.com/Unisolar-Flexible-...ds=solar+panels
http://www.uni-solar.com/products/commercial-products/pvl/
No
Penetrations
Durable
Lightweight
Easy to
Install
Shadow
Tolerant
TECHNICAL DATA SHEET
ePVL 144 | 136 | 68
Building on 25 years of solar experience, the new, enhanced version of our proven PVL delivers greater
efficiency, packing density and ease of installation, resulting in a lower cost of electricity than ever before.
Key Attributes
• Lightweight and flexible
• Roof-friendly solution requiring no penetrations
• BIPV & BAPV
• Superior performance at high temperatures
• Excellent performance even when partially shaded
• Built-in strain relief reduces installation labor and improves reliability
• Polarized, latching connectors
• Lead-free RoHS compliant design
Performance Characteristics
Rated Power (Pmax): 144, 136 or 68 Wp
Tolerance of Pmax: ±5 %
Mechanical Characteristics
Junction Box: IP66 terminal housing with integrated strain relief
Connectors: Polarized, weatherproof latching connectors with 4 mm2 (12 AWG) halogen-free cables
Bypass Diodes: Connected across every solar cell
Front Surface: Durable ETFE high light-transmissive polymer
Adhesive: Peel and stick pressure sensitive adhesive (PSA)
Cell Type: Multi-junction amorphous silicon solar cells 356 mm x 239 mm (14" x 9.4")
Certifications and Warranty
• UL 1703 Listed by Underwriters Laboratories® for electrical and fire safety (Class A Max. Slope 2/12,
Class B Max. Slope 3/12, Class C Unlimited Slope fire ratings) for use in systems up to 600 VDC
• IEC 61646 and IEC 61730 certified by TÜV Rheinland for use in Class A PV systems up to 1000 VDC
• MCS Certified
• CEC Listed
5-Year Limited Product Warranty
Limited Power Output Warranty: 92% at 10 years, 84% at 20 years, 80% at 25 years (of minimum power)
Application Criteria*
Suitable for installation on clean, dry approved substrates (refer to uni-solar.com for full details) at ambient temperatures above 10°C
Roof Requirements
Maximum slope of 60°
Install in areas free of water pooling
Edited by frscke1 (July 13th 2012 12:00 am)
#573803 - July 13th 2012 12:04 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
this diagram was on that site also...thought people might like to see....
#573812 - July 13th 2012 1:22 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
I have a Unisolar 68 watt thin film flexible panel on my raised fiberglass roof, in addition to the 130 watt Kyocera framed panel.
If your chevy roof has valleys, well the unisdolars are not that flexible.
Ram4ever has two Unisolar PVL68 he plans on adding. He is going to fill in the roof valleys with some foam and fiberglass over that to make the roof perfectly smooth to adhere the panels.
I am very impressed with the additional output from the Unisolar thin film panel. It is 9'4" long and 15.5" wide. The 128 watter is 16 feet long so that is pretty much not in the picture for a vanstillation. A shame cause the 128 watters are cheaper than the 68 watter.
The Unisolar seems to put out it's maximum rated output 3.5 hours either side of Noon mounted on my roof. The Framed Kyocera flat on my roof is about 1.5 hours either side of noon.
Though the Vmp and VOC are not as close as they should be (within 10% )between the 2 panels they really seem to behave well together, and on a summer day of full sun I can harvest about 100 amp hours.
I could tilt the Kyocera for more juice, as long as it is not shading the unisolar, and depending on the parking angle, even with the shading.
The unisolar really seems to do great on overcast days too. Though the unisolar added only about 50% more watts, on an overcast day I am seeing about 100% more energy returned to the batteries.
Unisolar is out of business, another victim of Chinese undercutting if not outright tech theft. Any panels for sale are leftover stock and prices will probably just rise as it is depleted.
Seeing as how a group 24 battery is around 85 amp hours, this is a pretty good amount of silent, and after purchase, free energy.
#573839 - July 13th 2012 10:41 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Ive got 13' of roof so when I park I can roll out the 9' 4" film onto the roof..I dont have to peel & stick it to use it and roll it up to put away, when Im done.....I already got the controller you suggested
#573844 - July 13th 2012 10:53 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Buying a "out of business" means no warranty ? Or If I need to get a replacement part...Who makes them now ?
Is Unisolar really that good to buy a "OOB" part ?
Edited by frscke1 (July 13th 2012 10:54 am)
#573849 - July 13th 2012 11:05 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
You should not roll the panel up tighter than 16 inch diameter.
Apparently they are still in business, just filed for bankruptcy. Not sure I know or would understand all the details of that.
There are no parts to replace. Warranty is more against outright failure and that it should still produce x% of original rating after x years.
Despite the excellent low light performance of the unisolars, for a portable/ temporary install, I'd get a larger wattage framed panel.
#573852 - July 13th 2012 11:10 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Thank you kindly....
3 registered (keystonekid1978, Superbeast, Nimrod), 5 Guests and 61 Spiders online.
Uncle_Fester 306
Wizard78 299
NateNCBV 230
frscke1 208
keystonekid1978 133
Lee7673 130
al55 121
newkirkinc1 112
Ripper 111
Mikemod63, cammyjee, sandalscout, jonnyray, JnyQst
6611 Registered Users
6612 Members
25975 Topics
