Seller beware and LIVE
Radio Shack van
Interview with Tommy Turtle of L.I.V.E.
06:37 PM
06:31 PM
Lookin' out my Side Doors
06:30 PM
06:20 PM
06:18 PM
06:17 PM
Page 3 of 3 < 1 2 3
#573882 - July 13th 2012 1:48 pm Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
HomeBrew Offline
Loc: Ohio, USA
Thats sweet! I keep tring to think of an affordable way to generate power while camping (without running a generator).
#573948 - July 14th 2012 12:20 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Well I just ordered a Unisolar 128 Watt Flexible Solar Panel PV Laminate roll up solar panel...and I got the Morningstar SunSaver SS-10-12v Charge Controller 10A 12V coming in on Monday...
#573950 - July 14th 2012 12:29 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Quick, cancel one or the other.
I can't find the chart for the 128 watter but I am pretty sure it is a 24 volt nominal panel.
Connect that to a non MPPT charge controller, or one only rated for 12 volt panels, and you release the magic smoke!!
Edited by wrcsixeight (July 14th 2012 12:33 am)
#573953 - July 14th 2012 1:06 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Done, it is a 24 v system I had to email the seller and he is going to cancel the order....Now back to the search...cant cancel the controller its already on the way....
#573956 - July 14th 2012 1:20 am Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
That panel came up as I searched 12v systems.....so I made a asumption that it was a 12v system....thanks for the save 68....again
#574153 - July 15th 2012 2:15 pm Re: Inexpensive Solar. 100 watts 140$ [Re: wrcsixeight]
Sorry for not getting back sooner.
I am a little confused by morningstar's product, and what it can handle as it says it is for 12 or 24 volt systems. I am not sure if a 24 volt panel would release the magic smoke, or if the controller would only output ~50% of the panel's juice. I would think for a 24 volt system it could handle a 24 volt panel, but whether it could step down the voltage and double the amperage as a MPPT type controller does is unlikely.
But it is best to be sure.
Generally 24 volt panels need a MPPT type controller and those are significantly more expensive than a PWM.
With a 10 amp charge controller I think you should look for a 12 volt nominal panel in the 180 watt or under range. But most panels over 140 watts are 24 volt nominal panels.
The open circuit voltages will be around 20 volts. The voltage at max power will be around 17.5.
If the 20 amper is not too much more and With Amazon's easy return policy, You might want to get the bigger controller just in case you find that your solar is short of your needs and you want to add another portable panel. But you can also just get another 10 amp controller and run them in parallel if more becomes necessary.
To take max advantage of the panels energy, you want to use pretty thick wire between panel and controller. At least 10 awg, and even 8 awg if you have 25 feet between controller and panel, one way.
http://genuinedealz.com/
Pretty good prices, free and fast shipping.
Also for ease of connecting and disconnecting the panel to the charge controller:
http://www.andersonpower.com/products/standard-powerpole.html
You do not want to bust out the screwdriver every time to connect the panel to controller.
Page 3 of 3 < 1 2 3
2 registered (86ed, GhostRyder), 2 Guests and 103 Spiders online.
Uncle_Fester 302
Wizard78 297
HighwayStar 256
NateNCBV 234
al55 121
newkirkinc1 110
6609 Registered Users
6610 Members
25969 Topics
