Today at 01:19 AM
Bad tornadoes in Oklahoma City
by starwars
Today at 12:44 AM
Today at 12:33 AM
VAN PAINTINGS AND ART
by MACE
Today at 12:31 AM
Astro drag van from Hot Wheels
Today at 12:30 AM
van sighting in southern indiana
Today at 12:19 AM
Today at 12:17 AM
Hello from Alabama
Today at 12:14 AM
Hello from Utah
Today at 12:13 AM
Today at 12:12 AM
Page 8 of 8 < 1 2 3 4 5 6 7 8
#578494 - August 10th 2012 9:23 pm Re: chop top early dodge [Re: 66NODOOR]
Not really sure why any one would remove filler then apply primer.???????
Most fillers still need good bare metal to adhere well to the steel....
There might be some thing out there I have not stumbled across yet
........Wookee
#578521 - August 11th 2012 1:58 am Re: chop top early dodge [Re: 66NODOOR]
radicalran Offline
Loc: Shanghai China
That was the way that I was taught. The cleaner the metal better your chances of a permanent repair. I'll see if I can find where I read it.
#578545 - August 11th 2012 10:39 am Re: chop top early dodge [Re: 66NODOOR]
scruloos Offline
Loc: vermont
you can put filler right over dry epoxy primer...alot of the hotrod shops do it because when old sheetmetal is acid-dipped or media blasted,it turns rusty very fast.i've done this myself and have had excellent results because epoxy primer is the only primer thats waterproof....
#579027 - August 14th 2012 3:48 pm Re: chop top early dodge [Re: 66NODOOR]
66NODOOR Offline
Loc: Edwardsville IL.
I should have said it would be done in slick sand, just like 2k, and then epoxy primer. I want to do the body work and let it stand before i put the paint down. I don't plan to let it sit outside it has a place in the shop now, and a spot in the garage at home, when done.
Denny Smith JR.
member # 132
Vanatics Springfield IL
IF YOU'RE GOING TO DO IT
DO IT IN A VAN!
#579035 - August 14th 2012 5:49 pm Re: chop top early dodge [Re: 66NODOOR]
radicalran Offline
Loc: Shanghai China
Denny, I was just curious. Can't wait to see the van finished. Enjoy!
#582198 - September 04th 2012 12:00 pm Re: chop top early dodge [Re: 66NODOOR]
66NODOOR Offline
I got a little time to start setting up for the rear axle. I had found a set of 33 19.5 M/T sportsman's on weld pro star rims, just for fitting the axle. Should be just right.
Denny Smith JR.
member # 132
DO IT IN A VAN!
#582386 - September 05th 2012 1:38 pm Re: chop top early dodge [Re: 66NODOOR]
Chopped and Pro Street. I like the direction you are going here.
........Wookee
#582400 - September 05th 2012 4:16 pm Re: chop top early dodge [Re: 66NODOOR]
cool!
#583640 - September 13th 2012 12:51 pm Re: chop top early dodge [Re: 66NODOOR]
Nice to see you working on this again.
Nice meeting you in person at the Nats too!
0 registered (), 3 Guests and 71 Spiders online.
NansZ
Uncle_Fester 281
Wizard78 273
HighwayStar 248
NateNCBV 230
frscke1 221
keystonekid1978 132
Lee7673 127
Reed 106
newkirkinc1 106
Edoz, FordVanMan66, SpringWater, Dale38, mbernhardt
6602 Registered Users
6602 Members
25937 Topics
